Z06 block or 6.0??
Old Apr 27, 2004 | 09:06 PM
Hit Man X's Avatar
Originally Posted by greentahoe
Wouldnt I be giving up some strength if I were to bore it out?? I would still need headwork or new heads to keep compression down right???
What ARP hardware would I need???
Wouldnt a 6.0 be cheaper and more reliable when all is said and done??? Just trying to get things straight.
Well that depends on how much you bore it. The 6.0 has a 4" bore, LS1/6 3.90".
Heads will be dependant on the block you choose.
I'd use ARP: main bolts, rod bolts, head studs.
The 6.0 LQ4 is the cheapest route for a junkyard pullout for the blower. Bigger bore, big chamber LS6 heads, etc.
Old Apr 27, 2004 | 09:19 PM
greentahoe's Avatar
So how does a 6.0 pullout with the ARP hardware sound?? Id keep everything else stock and add the vortech and go with 10#. What would be involved in getting a 4L80 to bolt up or should I just go with the FLP 4L60. I would think that the 4L80 would bolt up easily and be cheaper since the HD trucks come with the 6.0 and 4L80. Sound about right??
Old Apr 27, 2004 | 09:39 PM
Hit Man X's Avatar
If you're gonna break it that far down, I'd get some forged lower comp pistons... like 8.5-9.0:1, TSS rings, and hone it. New top shelf bearings. New oil pump. New gaskets. Double roller timing chain.
Hell I'd do a mild cam now too since it's out.
Stock crank can hold well over 600rwhp. Stock rods are like a forged I-beam for the most part...they are powdered metal. I'd do pistons for long term durability.
Boost doesn't like compression. How much boost can that blower push on a low comp motor?
The 4L80E is a longer and wider tranny, it fits pretty easily with a custom x-member, wiring plug, and a tune. That's about all you need with it. A stock 3/4 ton trannies are usually good well over 500rwhp before taking a ****. As Whitt1 he's got one in his Tahoe. You'll need the 4L80E flexplate and crank spacer too.
I'm pretty confident the limits of a 4L60E are 450-550rwhp in a truck. Much more is on borrowed time. If you plan much more than that, a 4L80E may be smart to go to when you 4L60E takes a crap.
Old Apr 28, 2004 | 09:18 AM
Ling_650vette's Avatar
I'd say it depends on the trim of the blower, and how your pulleys are setup. Cause i think even some of the smallest Prochargers (w/ the IC, and yes i know he's talkin about Vortech, but they're fairly similar) can push like 28psi.
But Hit Man's hit it right on the head drop the compression down a bit, forged pistons, better heads, ARP hardware all the other accessories, and be done with it.
kalikid06
20
Oct 13, 2015 07:37 AM
mitchellmade
Sep 27, 2015 08:27 PM
chvy=power
Sep 8, 2015 11:06 AM
Closer_2001
Sep 7, 2015 09:40 PM
