for you lsxrt guys
Old Jul 21, 2012 | 01:32 AM
greasemykey's Avatar
Default for you lsxrt guys
i bought this intake and im trying to install my throttle cable bracket and when i screw it down to the intake its pulling the throttle blade open about 25%. is there another braket or spacers i am supposed to use? the instructions dont show anything about this.
Old Jul 21, 2012 | 12:46 PM
ltr450ryder's Avatar
No it should work mine does with no problem. is there 2 holes on it tb for the cable to go I'm and if its on the bottom one it will do that move it up one and try that
Old Jul 21, 2012 | 03:15 PM
ok i think because my bracket maybe bent somehow thats why its not fitting the other holes. ill try bending it and see what happens
Old Jul 22, 2012 | 01:56 AM
well its not bent i have something else going on. ill take a pic tomorrow to show you that it only fits in 1 set of holes. i might have to make a aluminum plate tomorrow and bolt the bracket to that to get it to work. its like installing the TB spacer without the bracket extensions.
Old Jul 22, 2012 | 08:57 AM
Petey62782's Avatar
MASS seller approved
I'm pretty sure u can adjust a little on the cable from the foot pedel so u should be able to get the little slack u need
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
