YES.....Cam help
Old Jul 27, 2006 | 12:23 AM
the advantages for us genIII engines is they like better lift, in the older SBC you see .4xx for decent lift but essnetially the higher lift, the more power but if you try to go too big lift you end up maxing out your heads for example, a .600 cam vs a .632 lift cam, even though the latter has a higher lift, your heads max flow may be at .599 therefore, anything beyond that is over kill. a stock Z06 cam has .550 lift. you can easily run higher than that especially with your choice in springs. higher lift wont rob you your low end like higher duration either
Old Jul 27, 2006 | 09:25 AM
joehawkz71's Avatar
Originally Posted by moes04silverado
Comp Cams Xtreme RPM Cams
216/220 .525/.532 114
go with comps 918 springs and chomemoly hardened push rods at 7.40" length.....
i think this is a good cam fit for what you have...IMO
that was the cam that i was looking at but i want more lift then that!!! I want to utilize my 918'S
Old Jul 27, 2006 | 10:02 AM
joe, i was reading your sig, do you have a stall that you plan on using that 40kGVW cooler for?
Old Jul 27, 2006 | 06:23 PM
joehawkz71's Avatar
i bought the cooler about 2 months ago and i was planing on puting a 3200 verter in there but i turned away from that because i dont have the money to get a 80e and the 14 bolt rear end to handle all the power and with the 35" tires!!!
Old Jul 28, 2006 | 12:23 AM
i would buy it from you.... depending on your price of course and what fittings it needed but what power are you talkin about, lookin at your sig, you should be able to hold up with out having to upgrade your rear end and to an 80. unless im missing something of course
Old Jul 28, 2006 | 09:32 PM
willyfastz's Avatar
Restricted User
This is a small cam but it makes up for it's size with performance. And is about as big as you should go with a stock style converter.
212/218 .531"/.531" 113/109
Old Jul 29, 2006 | 12:49 PM
joehawkz71's Avatar
i would just asume to keep it considering i will be getting the 14 bolt and 80e probably sometime in the next year or two....my dads company just has to sell the truck that my dad drives and ill have it and a 6.0L (the trucks is a silverado 2500) ....10 bolts arent the strongest once you put 35" tires on her and more hp and tq...
Old Jul 29, 2006 | 12:51 PM
joehawkz71's Avatar
i think someone has a high lift version of this cam...bigger the .531. i was also thinking about that cam as well...
Old Jul 29, 2006 | 01:00 PM
willyfastz's Avatar
Restricted User
It's a good performing cam and you don't always have to have a lot of lift. The cam in my car is only .549" lift and it put down over 400 hp to the wheels.
Old Jul 30, 2006 | 12:19 AM
there really isnt any reason to go with higher lift than the lift at peak flow in your heads but more lift rarely hurts until you get into the .6xx
