Yank TT3200
Old Jan 27, 2005 | 07:39 PM
ASkipper's Avatar
11 Second Club
Default Yank TT3200
I would like your poinions on putting a Yank Truck Thruster 3200 stall 2.7 STR in my reg. cab Z71.I have 285/75R16 BFgoodrich all terrain tires.I also tow a 2000 lb. boat during the summer.Do you think I will have any problems with it.Thanks guys in advance.
Old Jan 27, 2005 | 09:02 PM
Breeze's Avatar
11 Second Truck Club
I would stick with the TT3000 if you're gonna be towing. Be sure to get you're self a trans cooler
Old Jan 27, 2005 | 09:15 PM
IslandTahoe's Avatar
I went from a TT3000 to a TT3200 and I would say unless you are a dedicated racer who is at the tracks often, I would stay with the TT3000. Especially with the towing, a TT3000 is more than enough for a daily driver. Even with my tall wide tires & posi rear-end, I lose traction at launch so when I swap out my tranny I will go back to the TT3000.
Old Jan 27, 2005 | 10:12 PM
BigTex's Avatar
I'll back these guys up. The TT3000 is pretty good. If you want more, I'd look into the multi disk Precision converters. Several 2800 vig users really like them in their trucks. The pi2800 stalls more than the tt3000 I think.
Old Jan 27, 2005 | 10:45 PM
I talked to someone at yank about this very same dilemna except my boat is around 4000lbs and he said to stick with the TT3000 even tho I only tow it to the lake and back once each way. Im putting it off until I get to drive a truck with a stall.
Old Jan 28, 2005 | 12:23 AM
well when you swap out trannys hit me up with a good price on that yank 3200
Old Jan 28, 2005 | 09:30 AM
zippy's Avatar
more importantly in that choice is what gear you're running with those 285's.
Old Jan 28, 2005 | 03:54 PM
ASkipper's Avatar
11 Second Club
The reason I was asking I got a deal on a converter from my friend for $200.I helped him to purchase it and he sold his truck.I know he has used it to tow a 4000lb boat before,but he had it in a 2WD with 3.42 and it acted fine.My 4WD has 3.73 and I will only tow a 2000lb boat once in a while.
Old Jan 28, 2005 | 03:57 PM
zippy's Avatar
sounds like a great deal on the converter. it may run hot alot with your truck being geared so tall. 3.73's with that tire height is way tall especially to be running that much stall.
Old Jan 28, 2005 | 04:53 PM
KeukaZ71's Avatar
i tow a 5000 lb boat and trailer with my 3000 stall. i wouldn't want any higher stall. the yank 3000 pulls fine. very streetable. no one can tell that it is there unless i get on it.
get the yank 3000. trust me
