Yank 2800 vs. Yank 3000
Old Jan 24, 2003 | 10:48 AM
SmokinLM7's Avatar
Default Yank 2800 vs. Yank 3000
I was serching the web and found some dyno runs with a YANK TRUCK THRUSTER 2800 and a YANK TRUCK THRUSTER 3000, but couldn't deside on which was best. Which do you guys think is a better converter? Which would you recomend using?
Oh and does the gear ratio have anything to do with how the converter works. My truck has a factory limited slip and 3.42 gears. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Thanks for the help. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 24, 2003 | 11:19 AM
BigTex's Avatar
Default Re: Yank 2800 vs. Yank 3000
If you install a converter, you will want to get some sort of locker. Its going to make that initial hit to the rear wheels much harder. On which converter is best, it depends on your mods. If you do a power adder of some sorts, or do lots of heavy towing, you might want less stall. If you are basically stock or want more rpms for street / track races, go for higher stall. The more power you make, the larger the converter will stall. So a 2600 stall behind a stroker motor will stall much more than 2600.
Old Jan 24, 2003 | 11:34 AM
1999stepside's Avatar
The higher=more fun!!!
Kent
Old Jan 24, 2003 | 02:19 PM
Patrick G's Avatar
LS1 Tech Administrator
Anything less than 3000 will have you wishing for more. Works awesome in my heavy 5400 lb. tank. Just look at those 60' times on stock radials.
Old Jan 25, 2003 | 12:42 AM
I would have to say 3000.I've had mine for a while now and had no complants.Diffenatly don't go 3200 if you plan on any towing. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Jan 25, 2003 | 12:43 AM
Old Jan 25, 2003 | 12:49 AM
I'd say go with the 3000 as well. I have a Vigilante 2800, but now I wish I'd gotten the 3200. I don't do any towing though, so I wasn't worried about that part.
Vortec350ss
Jan 12, 2016 10:36 PM
TAPyvehc93
Dec 27, 2015 12:14 PM
Wrecker 426
Oct 7, 2015 12:11 PM
trxmxzx
Sep 29, 2015 07:42 AM
RONIN LSX
Sep 19, 2015 05:33 PM
