Y2K Silverado's Pro Cold Intake
Originally Posted by Slowverado
i would too....i would have to see some hard core facts too. low2000, look at it this way.
if a tube with obstructions in it makes more power than a smooth one, why do vettes and fbodies have smooth intrances with no baffles in the tube or anything? why did older model cars come with smooth tubes (back when people didn't care about intake sounds) i mean come on, name me one HIGH PERFORMANCE vehicle that has big ole baffles in the intake setup.
Jim
How big is the pipe ID and OD?
I think one of these with a UPD tube or any other brand would be pretty badass.... Just not badass enough for me to spend $ on it... I'll get me some stainless exhaust pipe that is mandrel bent and weld a plate on it and go....
(I know how i said it, that it seems simple, probably wouldnt be... who knows...)
Jim
Procold uses the stock tube and Volant uses a tube both with air mufflers attached inline. The reason is that some vehicles especially vehicles set up for torque (hello trucks) use & need the extra air contained in the air mufflers for response when you go to WOT or are needing the power down low in RPMS.
The intake tubes that use air mufflers help give you more air on demand by having some in reserve instead of waiting for everything to catch up to WOT.
The vettes do not have air mufflers because the and not anywhere near a truck in design and do not typically have the same HP to weight ratio and hence would be less dependant on torque as trucks are. Vettes are obviously built for speed and any Silverado coming out of Detroit was not designed “stock” for ripping through the quarter.
Volant and Procold have both said they use them because they make more power with them so – hello maybe they are doing it right and you’re getting robbed with the others?
Originally Posted by onyx_silverado
tuck2... your getting annoying....
Jim
no he's annoying (tuck2) because he's obviously with procold and won't come clean. I don't have a problem with the unit but don't come on here acting as if you're just some end user that has found a great product.
