y pipe end worn away>>>> repair??
Old Jan 24, 2015 | 05:31 PM
40series's Avatar
Default y pipe end worn away>>>> repair??
ok, half of the y pipe wore away due to improper torquing off the clamps.. now i have a leak at the clamped area of y pipe.i tried to re clamp up on the y pipe but it came loose so im figuring there not enough y pipe left to clam on
im thinking i can get a band clamp to join both Y pipe and tail pipe what do you guys think??
granted i want to do all this with out removing the Y
Old Jan 24, 2015 | 06:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Pics?
How thin is the metal of your Y pipe? You may be better off to start with a new Y? Those Pacesetter Y's aren't very much money.
Old Jan 24, 2015 | 08:04 PM
batboy's Avatar
11 Second Club
A good muffler shop should be able to weld in a new piece for a reasonable price.
Old Jan 24, 2015 | 08:14 PM
40series's Avatar
Originally Posted by aklowriderz71
pics?
How thin is the metal of your y pipe? You may be better off to start with a new y? Those pacesetter y's aren't very much money.
this is not my set up but im thinking i can do this i will take my pics soon also if you look close at the clamp joints it looks as if he has some sor t of aluminum foil in the joints for sealing purposes i dont know
Old Jan 25, 2015 | 12:48 AM
gamble686's Avatar
Looks like a band clamp and someone decided to throw some exhaust wrap on for extra sealing.
Old Jan 25, 2015 | 02:21 PM
40series's Avatar
Default pics
i tried to put a 3 inch clamp on but its not clamping down on enough of the 3 inch header collector i tied to expand the u bolt to get more clearance but its not working i need some hotter heat o... any thought??
Originally Posted by AKlowriderZ71
Pics?
Attached Thumbnails y pipe end worn away>>>> repair??-cam01781%5B1%5D.jpg   y pipe end worn away>>>> repair??-cam01784%5B1%5D.jpg   y pipe end worn away>>>> repair??-cam01783%5B1%5D.jpg
Old Jan 25, 2015 | 07:50 PM
GM1697's Avatar
Looks like it just rotted... you're gonna need a new section of piping.
zblee
63
Jun 10, 2023 01:25 PM
GMCtrk
Dec 18, 2015 04:47 PM
Denali08
Aug 9, 2015 04:34 PM
Ketis
Jul 23, 2015 12:37 PM
