Would you run this motor if it was yours?
Old Jul 7, 2017 | 01:29 PM
  #61
trxmxzx's Avatar
13 Second Truck Club
Originally Posted by madmann26
Yes. If there is a rotation or stepped torque values, follow that as well.
well I reread what I asked that sounded dumb. Seeing these ARP bolts (not studs) are not stretch bolts. How do come up with the proper torque? And the use of there lube needed correct?
im used to the stretch method
First stage: Using a torque wrench, tighten the M11 bolts numbered 1 through 10 in sequence to 22 ft lbs.
Second stage: Now use a torque angle gauge to add 90 degrees of twist to the same bolts, again in sequence.
Final stage: The specifications to use in the stage depend on the style of head bolts that your block uses.
2004 and later blocks with all the same length M11 bolts: Add an additional 70 degrees of twist to the bolts in sequence.
2003 and earlier blocks with long/short M11 bolts: Add an additional 90 degrees of twist to the bolts numbered 1-8 in sequence. Then add 50 degrees of twist to the shorter M11bolts in locations 9 and 10.
Once all M11 bolts are secured, use a torque wrench to tighten the M8 bolts numbered 11-15 in sequence to 22 ft lbs. There is no angle to add to these bolts..
Old Jul 8, 2017 | 09:39 AM
  #62
trxmxzx's Avatar
So do I do 72ftlb?
Old Jul 8, 2017 | 12:28 PM
  #63
03sierraslt's Avatar
Torque them to ARP instructions.
Old Jul 8, 2017 | 02:35 PM
  #64
trxmxzx's Avatar
Thanks! How about that lube I hear about? Or is that for just studs
Old Jul 24, 2017 | 06:19 AM
  #65
trxmxzx's Avatar
So I took the top end of this lq9 apart- why is one side clean - pushrods clean ones are passenger side dirty ones are drivers side
Old Jul 24, 2017 | 07:03 AM
  #66
ZR1 DREAMING's Avatar
Use the lube ARP provides, make sure to hit the washer as instructed too.
Old Jul 24, 2017 | 07:25 AM
  #67
Yep, exactly. Just follow their instructions.
Old Jul 24, 2017 | 08:49 AM
  #68
trxmxzx's Avatar
funny after I brought all this up, I opened the package and the lube was in there and torque specs... I'm a idiot and should have looked further into it.
Old Jul 24, 2017 | 09:42 AM
  #69
Ain't nothin wrong with asking questions and learning!
Old Jul 25, 2017 | 12:52 AM
  #70
FFDP's Avatar
Blame the PCV system for the half dirty parts, I would at least.
stealthperf
34
Feb 14, 2016 11:35 AM
CammedZ71
Aug 2, 2015 01:44 AM
silver-mod-o
Jul 27, 2015 05:24 PM
jmarkway
Jul 18, 2015 09:23 PM
Nimoryan
Jul 5, 2015 03:50 PM
