Would it be worth installing 6.0 injectors on a 5.3?
Old Jan 26, 2004 | 03:11 PM
14 Second Truck Club
Default Would it be worth installing 6.0 injectors on a 5.3?
Would it be worth installing 6.0 injectors on a 5.3? Would it help me out when I get my heads done and possible nitrous set-up? Also, doesn't it make it easier on the ECM?
What do the stock 5.3 & 6.0 injectors flow?
Thanks.
Old Jan 26, 2004 | 03:51 PM
BigTex's Avatar
Only if you are running lean due to lack of fuel injector. Your 99 is the only model with the smaller injector, all 00+ 4.8 and 5.3s have the same size injector as the 6 liter. You have a 21.x pounder while everyone else has 24.5 pound injectors. I made about 300 rwhp on my 99 and wasn't quite out of injector yet.
Old Jan 26, 2004 | 07:14 PM
So when I do the heads and gain 15-25rwhp to put me in the 300+ rwhp range, would it be best just to replace the injectors with the newer ones to be safe?
Thanks for your input
Old Jan 26, 2004 | 07:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
I think the 5.3 and 6.0 injectors are the same....someone correct me if I am wrong.
Old Jan 26, 2004 | 10:29 PM
BigTex's Avatar
Read the first reply to his question.
Old Jan 26, 2004 | 11:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
Duh, I can read ociffer
Choda
Jan 22, 2026 02:03 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
