Would 6.0 heads give me any power?
Old Sep 25, 2003 | 06:31 PM
Default Would 6.0 heads give me any power?
Well im the middle of puttin together my 6.0 and since nobody wants to buy the stock heads off of it i was wanderin if i put the stock 6.0 heads on my 5.3 if it would give me any power? im sure it wont help any but i thought id ask>?
Old Sep 25, 2003 | 07:13 PM
Banned
Default Re: Would 6.0 heads give me any power?
it would definatly help....not worth the trouble of a head swap, but it would definatly help with the cam you already have. they flow a ton better than the 5.3 heads, and they have bigger valves for more airflow, the exhaust port is awesome on those heads(6.0/ls6) also.
Old Sep 25, 2003 | 07:23 PM
So even though it would help u dont think its worth it? how much of a gain am i lookin at?
Old Sep 25, 2003 | 08:07 PM
Banned
15-25 HP MAYBE....doubtful, but maybe
Old Sep 25, 2003 | 08:30 PM
SO U THINK I SHOULD TRY IT? OR TO MUCH OF A HASSLE?
also my pistons didnt come with wrist pins which i thought they would...wheres a good place to find some wrist pins?
and the place that is puttin my cam bearings in my block said they need my cam...i only have my stock cam right now and im gonna run a bigger one...could this cause problems? sorry for all the off subject questions...thanks!
Old Sep 25, 2003 | 09:56 PM
Banned
i wouldn't bother with it if you're gonna have a new motor. as far as the wrist pins i would call the place you got the pistons from and talk to them about that. and for the cam bearings it should be fine to just send them your stock cam....they just need to know the outter diameter of the journal or whatever it is.
Old Sep 25, 2003 | 10:17 PM
Yelo's Avatar
I will buy the stock 6.0 heads if you can give me until late October......
Old Sep 25, 2003 | 11:01 PM
IF I STILL HAVE THEM THEN..THEN I WILL LET U KNOW
Old Sep 25, 2003 | 11:04 PM
RED2K's Avatar
i would think you would lose some power due to loss of compression. They do flow better though so you should gain some in that aspect. I think you will gain more than a lose if you know what i mean. If you could get them milled that would be great
Old Sep 25, 2003 | 11:10 PM
Banned
mill them to the stock CR, and then a little more...say .030" beyone stock and you'd have a pretty decent setup. my new heads for the 6.0 are, pretty much a ported/polished 6.0 head with ferra 2.02/1.60 valves and rev dual springs w/ti retainers.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
fat tony157
Jul 16, 2015 12:35 PM
