is it worth keeping?
Old Oct 8, 2007 | 10:10 PM
dry_kill's Avatar
Default is it worth keeping?
well when i pulled the 4.8 out of the truck i found 2 or 3 (cant remember) small metal chunks about the size of marbles in the oil pan. not too sure what the were but i also know one of the valvesprings were busted as well. i plan on tearing the motor apart down to the bare block. now my question is is it worth keeping it and getting it bored? or should i just try to sell it. getting it bored would be for a project way later on down the road. can a bored 4.8 make any real power or is it best to get a 6L block?
Old Oct 8, 2007 | 11:16 PM
Tootall's Avatar
there's a few that are still trying to sell theirs . . . . keep it for a spare motor to blow up, or incase something happens to yours. The block is about the only good thing about it.
Old Oct 9, 2007 | 10:44 AM
Yogi Bear's Avatar
Even if you bore the 4.8 you still have the short stroke Max bore would only give about 5.2. Get a 6.0 instead.
Old Oct 9, 2007 | 12:16 PM
thunder550's Avatar
High on diesel fumes
You can make a forged 5.7 out of that block, if that's the way you want to go. Bore it out (not sure what size) and run a 4" stroker crank with the supporting hardware and you've got yourself a forged iron block 5.7L
Old Oct 9, 2007 | 09:04 PM
Onyx 02's Avatar
Bore it to 3.90" and use LS1 pistons and crank.
Old Oct 10, 2007 | 02:26 AM
thunder550's Avatar
Oops yeah, if you run the stroker crank and the LS1 bore like he said you get a 383. I forgot that.
If you run LS1 bore with LS1 crank, you get......duh.
Old Oct 10, 2007 | 09:41 AM
Yogi Bear's Avatar
Yes but, if he strokes it, he will also need new rods. And the combustion chambers on the 4,8 heads are too small for 5.7 or 383 displacement, so he would also need some 6.0 heads. It would be better to just put the money into a 6.0 long block.
Old Oct 10, 2007 | 10:24 AM
TXsilverado's Avatar
haha thats a given. ls1 or 6.0 heads are cheap. hell with a forged stroker motor im sure he would be looking into a nice set of AFR's
wretched73
Oct 28, 2015 09:21 PM
chopperloco
Sep 28, 2015 08:40 AM
69z-28
Sep 21, 2015 07:31 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
