Will these injectors be enough?
Old Feb 8, 2009 | 08:07 PM
budhayes3's Avatar
PT's Slowest Truck
Default Will these injectors be enough?
Well, forever planning my LQ9 project (since "planning" is all I can afford to do right now lol), and I just want to make sure that I have the right injectors for my set-up. The injectors are the 31lb 8.1 injectors (I bought them a long time ago for a great price), the cam is going to be the Vinci 220/224 .551/.551 114, and the heads are WCCH StageII 317's. I've read that the injectors actually flow 29.9 (KB racing posted that info)...will they work and have an acceptable duty cycle? Thanks!
Old Feb 8, 2009 | 08:12 PM
BlackGMC's Avatar
Resident Retard
a buddy of mine has the marine 8.1l in his 6.0 with a 224/224 cam and his IDC is like 76-78, so since your adding worked heads I think you will be pushing it with regular 8.1s.... Spend the extra 25-50 bucks and get the marines....
Old Feb 8, 2009 | 08:13 PM
sonoma43's Avatar
I would imagine on an LQ9 with those mods you would be somewhere around the 80-85% IDC mark! Should be good there it just wont leave a ton of room for anymore mods.
Old Feb 8, 2009 | 08:25 PM
budhayes3's Avatar
PT's Slowest Truck
I had a feeling that it would be close, the heads might just put me over the edge. Thing is, I already have the 31's...guess I could always sell them and upgrade if I had to. I could live with 80-85% IDC...BlackGMC, are your buddy's heads worked?
Old Feb 8, 2009 | 08:27 PM
nlawson6.0's Avatar
if u have a way to check duty cycle, i sure as hell would try them out before buying other one's since u have some now.
-nate
Old Feb 8, 2009 | 08:28 PM
BlackGMC's Avatar
Resident Retard
Nope they are stock 317s, just milled a little bit. BTW he is a member on here, dlt76028...
Old Feb 8, 2009 | 08:47 PM
budhayes3's Avatar
PT's Slowest Truck
I have a cheapo scan tool but it doen't do IDC But I do plan to get a BlackBear tune when I do the swap, so I can do some logging and see what Justin says. This whole project is a while away, but you know how it is, I like to have my ducks in a row
Old Feb 8, 2009 | 08:48 PM
BlackGMC's Avatar
Resident Retard
I say sell the 8.1 and buy some 8.1 marnines...
Old Feb 8, 2009 | 08:49 PM
blackbeast ss's Avatar
yep same here only im on the TSP 228R cam and at 80 IDC but stock heads too. .. .IMO id upgrade your injectors
Old Feb 8, 2009 | 08:53 PM
GMCtrk's Avatar
people run around 400rwhp on stock 28lb inj in f-body. I think you will be just fine. You will be at the limit though, so you will have to upgrade to the 42s if you want to go any past what you have planned now.
