Will I run 12s?
Old Nov 22, 2004 | 08:43 AM
derek_silvy's Avatar
Default Will I run 12s?
Alright -- here is the plan when I get back from basic (I actually won't be leaving until march)...
Here is what I'm looking @ on top of everything else I've got:
Eaton Positrac
Wet Nitrous Kit (75-100 shot)
Nittos
180 stat
Cutouts
So, how is that looking? Will I hit twelves on this with good weather?
Old Nov 22, 2004 | 09:04 AM
BigKID's Avatar
If track prep is good and you plan on spraying out of the hole, I don't see why not.
btw... what gears and stall do you have? That will come into play a bit.
Old Nov 22, 2004 | 09:08 AM
3.42s rear and a 3000 TCI stall
I do have a question though.... when I get that Eaton, does it come with some gears in it, or how does that work exactly?
Old Nov 22, 2004 | 09:12 AM
F8L Z71's Avatar
Slicks.......
Old Nov 22, 2004 | 09:23 AM
goshawk23's Avatar
Truck addict
when you get an Eaton you are only replacing the stock G80 unit if you have one. there will be no ring and pinion gear coming with the Eaton
Old Nov 22, 2004 | 09:59 AM
tooquick2beslo's Avatar
I have about the same setup as you and I ran a 13.5 @ 104 with absolutely no traction. I believe I can hit a 12 now. I just upgraded my tranny and put a stall converter in it. I think I can run a 12 if I can ever make it to the track.
Old Nov 22, 2004 | 10:47 AM
sfj
yes you should be able to good luck
Old Nov 22, 2004 | 08:17 PM
you should get you some et streets and you will be there easily spray as soon as you left off the brake like i do you have headers over me and a couple more things and i do.
Old Nov 22, 2004 | 09:50 PM
Yeah, I do have some headers, custom tune vs handheld, cam, stepside (lighter), and transgo and stuff over your setup.
So hopefully I could even bust a 12.5!
That'ld be awesome to go beat a C5 vette.
Old Nov 23, 2004 | 02:09 AM
chris99gmc's Avatar
if you are going to do a Wet shot... I would go with 125-150 with all your other mods.
some good traction with the tires and the Posi should get you 12's on a good day.
stealthperf
34
Feb 14, 2016 11:35 AM
The_W
Aug 15, 2015 08:07 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
00pooterSS
Jul 16, 2015 03:03 PM
