wideband 02 conversion
Old Apr 24, 2005 | 07:48 PM
02sierraz71_5.3's Avatar
Default wideband 02 conversion
Is there any way to replace the stock 02 sensors with wideband and use the stock wiring? Im interested in running a wideband for tuning do I need to place the sensor in the stock location or just make a third bung for it? What all is involved in making a wideband work with the stock pcm/vcm and also making it work with HP tuners?
Is one brand better than another? recommendations?
Old Apr 24, 2005 | 07:55 PM
99Silver6.0's Avatar
No to your first questiuon. FJO makes the best setup for an in vehicle wideband. But its not terribly cheap. The kit comes with a weld on sensor bung that you put in your y-pipe. Dont know if you can make an add-on wideband talk with the PCM either. Innovate makes a digital handheld wideband O2 setup and it runs liek 350 bucks.
www.innovatemotorsports.com
www.fjoracing.com
Old Apr 24, 2005 | 08:45 PM
KySilverado's Avatar
As 99Silver answered no you cannot use wideband and stock wiring. I researched this awhile back and did find that PLX had equipment that would enable you to use wideband sensor in place of stock 02. Believe they made a converter that then could be used to drive the signal to the PCM.
http://www.plxdevices.com/onlinestore_domestic.htm
SS94S10
Jan 3, 2019 01:57 PM
Silver8ado
Sep 30, 2015 11:42 AM
spooneralmighty
Sep 11, 2015 02:28 PM
madmann26
Sep 6, 2015 04:19 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
