Wide band arrived today...
It showed up too late to get the bung installed but I might get it done tomorrow. If so I should be able to log some runs sunday and then decide whether or not I need to step up to a larger injector. I think I know the answer already as I'm seeing 450 grams per second with the 3.0 pulley and the 2.9 will be here soon.
you are not even close to needing injectors yet
Ok..I'll bite......
I keep hearing there's a pretty close correlation between "Grams Per Second" on a boosted engine and rear wheel horse power....If this is true...At what AWHP should the injectors start getting close (42LB).....? I'm thinking 470-480ish AWHP...Maybe 500-550 RWHP..? Any ideas will help big time....
Jimbob
Jimbob
There you go with that "we" crap again!
With the intercooler and the meth and some boost, your truck is going to be STRONG dave......you'll think back to your non intercooled 5 psi days as playschool years.
With the intercooler and the meth and some boost, your truck is going to be STRONG dave......you'll think back to your non intercooled 5 psi days as playschool years.Trending Topics
No dice on the muffler shop bung install. They won't deal with the stainless tubing that I have stock.
So.... I'm going to disable the rear O2 sensors in the programming and either swap a front O2 sensor to a rear O2 hole and make this work or simply install the wideband in a rear O2 sensor hole. I only need it for the PE tuning and only as a temp install. Once we get it all set up and tuned I'll be taking the wide band back off.
Adkoonerstrator
Which wideband setup did you get?
