why did it quit pulling?
just wondering if anyone could have an explanation as to why my truck quit making hp at around 5500rpms. my cam is in my sig. and it should pull well beyond that. n/a it pulled to 5900 and would have pulled farther if not for the truck intake. so why with the radix did it quit so early. it was pulling 10.5psi of boost until 5400rpms and then started falling gradually, but at 6000rpms it was still at 9-9.5psi. any opinions???
were you data loging at all? there are a few diffrent things that can make you dbw tb close and that will kill power for sure. were you on the dyno? if so is you speed limiter set high enough for the dyno runs? i would check everything in the tune.
Originally Posted by trever1t
Better exhaust, yes. Still doen't explain the drop so soon. You have the springs and the Radix intake.....You should be spinning all the way up. Could it be the tune?
Originally Posted by Zick
What did your A/F ratio look like?
