Why couldn't you "belt-drive" a turbocharger ??
Old Sep 10, 2003 | 11:51 PM
Yelo's Avatar
Default Why couldn't you "belt-drive" a turbocharger ??
No, really, I'm being serious here.....why couldn't you split the case of say a T66 and replace the impeller housing and the exhaust driven impeller with an engine mounting plate and a custom-cut pulley, then run a longer-than-stock belt to turn the turbo. If you left the compressor side alone you would end up with a belt-driven turbocharger with no exhaust lag.....right ??
I mean this is basically all that a centrifugal supercharger is (Vortec/Paxton) isn't it ??.....
you could put a REALLY small pulley on the turbo to spin it REALLY fast so you would make good boost down low and as long as you used a standard adjustable wastegate set at say 10psi you would be able to limit total boost to a reasonable level
and then (assuming this whle scheme would work) you could mount up two of them and come up with a twin-turbo setup without all the hassels of exhaust routing, custom headers, and HEAT issues
I know it would be harder than I make it out to be but could it actually be done ??
Old Sep 10, 2003 | 11:58 PM
Deckhand's Avatar
Default Re: Why couldn't you
i think thats the idea of the centrifugal supercharger such as the ati .. etc
maybe it can be done? i dunno
Old Sep 11, 2003 | 12:07 AM
GoldenVelvet's Avatar
Thats what a centrifugal supercharger is. However direct drive is not enough RPM for the turbine, thats why ALL centrifugal blowers are internaly geared.
Old Sep 11, 2003 | 12:29 AM
Ryan23silverado's Avatar
yes, you must step up the rpms with gearing to spin the impeller blades fast enough.
Old Sep 11, 2003 | 01:38 AM
superchargers use power to make power, Turbos make free power technically. they actally plug up your exhaust a bit for normal driving.
Old Sep 11, 2003 | 01:50 AM
sleepersilverado's Avatar
you will find in some places they cal centrifical s/c a belt driven turbo or maybe it was the opposit calling a turbo a n exhaust driven s/c. dont rember but have came across it while doing research.
o and as far as the twin issue i will have custom twin ati's one day not any time soon though.
Old Sep 11, 2003 | 03:54 AM
LS1TECH Sponsor
Belive it or not but yelo has a good idea, so much so that somebody has already gone ahead and tried it. General Electric and General Motors (EMD) make diesel elctric locomotives GM has been consitantly able to offer more torque with a 2 stroke turbo diesel. Well GE is now testing a gear driven turbocharger that overruns (over running clutch) itself once exhaust pressure is sufficient. Turbochargers are more mechanically efficient then blowers.
Old Sep 11, 2003 | 08:27 AM
Deckhand's Avatar
Turbos, superchargers, twin ati..etc,etc is just a bunch of BS.. what you guys need is one of these
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430797683
lol..
SloSVO
Nov 22, 2020 07:34 PM
drummer0415
11
Oct 24, 2015 08:16 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
jscherbs
Sep 24, 2015 12:51 PM
okie454ss
Sep 23, 2015 09:18 PM
