Who here knows something about the 5.3's?
Old Aug 9, 2009 | 12:25 AM
taws6m6's Avatar
11 Second Club
Default Who here knows something about the 5.3's?
I was referred here from ls1tech. I am curious to know the differences between the different year model 5.3's from say 2000 to the present. More specifically an lm7. I want to get my hands on one. More than likely from a junkyard or off tech. Is there a more "desirable" year model of these motors performance wise? Seems like I read somewhere that the 03+models had better internals, I could be wrong though. This will be for a 5.3l turbo build. Thanks guys! I know my ls1's but jack about these others
Old Aug 9, 2009 | 12:38 AM
95 bright teal's Avatar
There are a few varieties of 5.3's
there is the iron lm7
the aluminum l33( lower compression, good boost motors)
iron l59 05+(flex fuel, larger injectors)
and the 07+ not sure on the code on them, but they come with better flowing heads and make more power stock
thats just a quick rundown off the top of my head, you came to the right place some of the experts will be able to fill in some more details
Old Aug 9, 2009 | 01:20 AM
ChevyTruck's Avatar
something else
http://en.wikipedia.org/wiki/GM_LS_engine
here ya go lots of reading to do, but well worth the time.
Old Aug 9, 2009 | 01:59 AM
Mangled03gmc's Avatar
Baltimore Whore
DING DIng.. Any one you choose will do the job... Naturally the later years you get will have the less miles on them... There are some guys here pushing the l33 to 550+ whp with no probs
Old Aug 9, 2009 | 02:03 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
wrong actually the L33 is higher with CR at 9.9:1 which is why it loves the modified roots blower!
Old Aug 9, 2009 | 02:34 AM
Oh I knew the l33 was better for boost and Assumed it was due to lower compression. So do they not respond as well to turbo applications?
Old Aug 9, 2009 | 03:03 AM
_zebra's Avatar
makes children cry
Originally Posted by trever1t
wrong actually the L33 is higher with CR at 9.9:1 ...
+1. it uses the same flat-top pistons as the 4.8 as opposed to the LM7 dished pistons
Old Aug 9, 2009 | 11:03 AM
budhayes3's Avatar
PT's Slowest Truck
I'm assuming that you will be swapping cams, but the 99's have the least desireable factory camshaft.
Old Aug 9, 2009 | 11:12 AM
Dirty 30's Avatar
LS1Tech Whore
LH6 represent! "LS6" heads, aluminum block, flat top pistons, kinda like a baby LS2.
Old Aug 9, 2009 | 11:22 AM
trever1t's Avatar
the L33 has those same features. I don't know of any Turbo's L33's but lot's of SC'd ones do fine What is the difference between the L33 and the LH6 VVT or DOD?
