whipple pully poundage for 3.5"?
hey,, just wondering if there is anyone with a accurate boost gauge to tell me how many pounds a 3.5 inch pully produces on a single pully whipple system. also, would it produce less on a 6.0?
It will produce approx. 2lbs less on a 6.0L engine (but flowing the same amount of air as if it were on a 5.3L) It will be under less pressure on the 6.0L so it will not be as hot. so there is an added bonus
I know Ranwalk runs a 3.5" pulley on his 6.0L setup.
Well, my whipple with a 3 1/8" pulley was pushing 5lbs at 3500ft above sea level...
I just installed a 2 5/8" pulley and now I am making 8.5lbs...now this pulley is supposed to be 10psi according to the guy at Whipple.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
sounds like you got the 2 belt whipple.. the pullies are alot different on those. stock pully on mine is 4 inches i think, and i get 6 psi.
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
