Another VSC question here!
Old Jun 13, 2004 | 07:15 PM
vanillagorilla's Avatar
Default Another VSC question here!
Okay, so I installed my LS1 fans this weekend, by using a VSC. They only come on when the AC is turned on. I've tried adjusting that little yellow temp adjust screw, but there are no numbers on it, it just spins and spins and spins and the fans never come on! WTF. Is the screw suppose to do that, or what? They keep the truck cool with the AC on, but with the AC off I'm affraid it might overheat before the damned VSC turns them on.
Oh, yeah, and they don't run for 30 seconds after the truck has been shut off. WTF!!!
Old Jun 13, 2004 | 07:29 PM
one03sierra's Avatar
Formerly one92rs
Talking
are you sure they are hooked to an ignition source. if the ignition source to the vsc is not on then it doesnt know that the ignition is on and the fans will not work.
Old Jun 13, 2004 | 07:36 PM
Pretty freakin' sure of that. I followed that websites instructions (http://home.nycap.rr.com/agreif/Index.html)
I used a pink wire, under the fuse panel, that's only hot when the key is in the "on" position. Is the srew just supposed to turn like that though?
Old Jun 13, 2004 | 07:41 PM
Formerly one92rs
Talking
http://www.flex-a-lite.com/auto/295.pdf
is it wired up like this.
Old Jun 13, 2004 | 07:55 PM
Yes, sir. That's how I did it! I guess I'm going to be on the phone with them Monday, bitching. Great!
Old Jun 13, 2004 | 08:24 PM
Formerly one92rs
Talking
hey does that screw go all the way around or does it stop in the middle.
Old Jun 13, 2004 | 10:30 PM
Nope, it doesn't stop in the middle. It just spins and spins and spins. It doesn't stop at all. Something tells me it should. I wonder if that could be the culprit?
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
