Whipple leaking oil?
Old Jan 2, 2005 | 04:35 PM
NateZ's Avatar
Default Whipple leaking oil?
There is a slight amount of oil around the part were the boost part of the whole thing (the part that connects to the piece that connects to the intake) and the compressor, and also there is some oil residue on the back of the mounting plate.... I checked the oil level it seems to be fine but were is this oil comming from?
Nate
Old Jan 3, 2005 | 02:27 PM
NateZ's Avatar
ttt any of you guys with whipples?
Nate
Old Jan 3, 2005 | 02:33 PM
moregrip's Avatar
what a rush!
damn bro, wish things were going easier for you. Best of luck, wish I could help more.
Old Jan 3, 2005 | 03:01 PM
gametech's Avatar
Could it be sucking in through the PCV?
Old Jan 3, 2005 | 04:11 PM
NateZ's Avatar
I was thinkin mabye it was the pcv cause the oil is kinda black and dirty and the oil in the blower is brand new? how much oil actually goes through that thing?
Nate
Old Jan 3, 2005 | 09:25 PM
James B.'s Avatar
It's got to be oil from the PCV. If that oil was coming frmo the gearbox of the compressor you would see a rapid drop in those levels and it would eventually eat itself starved of lube. You may want to look into installing a catch can. They seem popular with quite a few Gen-III owners.
Old Jan 3, 2005 | 09:28 PM
unklej's Avatar
Yep, I run a catch can in my 04 5.3 and I drained 20 ml of oil from 2000 miles of driving.
Jeff
Old Jan 9, 2005 | 07:31 PM
NateZ's Avatar
Jeff
Ok guys, i installed a catch can, hasn't caught a thing, i even cut a piece of the pcv line to see if there was any oil really goin through the thing before and it's dry as a bone. I checked the oil level today, normal. Where is this mystery oil comming from?!?! There is a thin film of it all around the bottom were the oil resivior on the supercharger is..... and a small little puddle were the outlet is for the bypass....
Nate
scooter k
Sep 16, 2015 10:32 PM
726.0chevelle
Sep 12, 2015 09:24 AM
cousblake11
Sep 9, 2015 06:52 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
