Whipple HELPERS!! Computer / Harness questions..
Old Oct 19, 2004 | 12:23 AM
digital's Avatar
Default Whipple HELPERS!! Computer / Harness questions..
I received my PCM from Nelson's today and have started the process of getting rid of the Whipple computer...
I've attached a picture with the two black wires that go to the two infectors in front of the motor, they lead from the Whipple Computer harness, where should they go now? Also, could you please take a look at the second harness photo and give me an idea of what goes to what??
Please help! Appreciate it...
Thanks,
Matt
BTW: This is a 2000 Silverado, 5.3
Attached Thumbnails Whipple HELPERS!! Computer / Harness questions..-whipple_wires1.jpg   Whipple HELPERS!! Computer / Harness questions..-whippleharness.jpg
Old Oct 19, 2004 | 12:39 AM
James B.'s Avatar
As I understand it the auxiliary injectors are no longer used with a tune for the stock injectors. The auxiliary injectors should be completely disconnected. Right?
Old Oct 19, 2004 | 04:13 AM
gametech's Avatar
The whipple should have come with a plastic plug to put in place of the computer plug. This bypass plug returns your factory harness connections that were modified by the whipple install. Once you disconnect the whipple computer, you should be able to remove any of the output wires such as the aux injector wires that are left. BTW Nelson uses some fairly aggressive timing, but oddly enough, a fairly rich WOT power enrichment setting. If you have access to HP tuners there are some good gains to be found fine tuning his program.
Old Oct 19, 2004 | 09:46 AM
digital's Avatar
I don't have the plug for the harness that returns it to factory...
So with the aux injectors, just leave them installed but with no power leads connected?
Thanks,
Matt
Old Oct 19, 2004 | 12:56 PM
CoonToot's Avatar
[QUOTE=digital]So with the aux injectors, just leave them installed but with no power leads connected?
QUOTE]
Yep, just unplug them at the aux injectors. Something else you can do is to remove the braided fuel lines that supply those aux injectors fuel, since they no longer need to be fed fuel. Personal choice here, as the stainless lines look nice, but really don't serve any function for you anymore.
RustyD
May 23, 2016 07:04 PM
Lthompson
Oct 2, 2015 12:45 AM
Cammed4ever
Sep 30, 2015 03:38 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
