Whipple is in :-)! But boost question
Old Dec 27, 2004 | 10:09 PM
moregrip's Avatar
what a rush!
Originally Posted by gametech
Because the blower is after the throttle, the boost is relative to throttle opening. As soon as you open the throttle all the way, you get close to full boost, regardless of engine speed. With the throttle partially closed, you restrict the amount of air going into the blower, unlike most centrifugals, where the blower gets the air before the throttle body.
Are you sure bro? Mine is like "right now" no lag at all!!!
I think it has more to do with the design and its weakness, "any off boost condition", like idle. Nothing against your choice at all NateZ
Old Dec 27, 2004 | 10:45 PM
NateZ's Avatar
I
t's just kinda weird, cause whipple preaches the no lag instant boost thing, and i have heard that as being a plus from other people of there design? i dunno... Mabye i havent bypasses the whipple electric bypass thing correctly or somthing still, i'll get into it tomarrow some.
Nate
Old Dec 27, 2004 | 11:06 PM
NateZ's Avatar
Originally Posted by NateZ
I
Nate
Let me rephrase just alittle....
If i nail it, i get instant boost. However, it's when i am just accelerating normally, i see zero boost, and zero vaccum, it sits in the middle. If i get on it alittle bit, it only makes like 4lbs of boost above say 2900. then it just shifts normally. Does that make any sense and does it sound about right? Mabye i just need to take a ride in someone elses blown truck so i can see whats goin on.
Old Dec 28, 2004 | 03:27 AM
METAL MAN's Avatar
You should get full boost right off idel at WOT. Sounds like you might have a leak someplace?
Old Dec 28, 2004 | 03:54 AM
Mr. Sandog's Avatar
Maybe it's operating fine.
The Radix behaves in the same manner. Floor it, instant full boost.....which is exactly what you are describing here as what the Whipple does when you floor it.
The rest of the time boost is throttle dependent. If I am idling, I am in full vacuum. If I give it gas, it raises up, and depending on how much gas I give it, I can make the boost gauge sit at zero, 1psi, 2psi, etc., all depending on how much throttle I give it (i.e. 10%, 30%, 50%).
The 4.5 lbs of boost you are getting may be exactly what you are supposed to be getting with the pulley you have, and the motor you have. Is that a Silverado SS you have? If so, the pulley that would give my LM7 6 psi would only give the LQ9 only 4.5 psi. Perhaps you have the wrong pulley for your motor.
Old Dec 28, 2004 | 08:28 AM
NateZ's Avatar
I think thats what i needed to here AV, yes it's an SS. It's the rightpully too, i see 4.5 when getting on it but not WOT, 5 at WOT until it's in the 5k range and then 6, so i think it's about right.
Old Dec 28, 2004 | 10:02 AM
00z71sierra's Avatar
I think it's fine the way it is. I have a Whipple on my 5.3 and from a standstill if I punch it will get instant boost. If I just drive normal in town I will barely see boost at all until I get into it again on the gas pedal. I can be on the highway doing 80 and as soon as I take my foot off the gas I'll see all vacuum. Like everyone else said it depends on the throttle position.
Have fun with it.
Old Dec 28, 2004 | 12:26 PM
NateZ's Avatar
Yea whats the deal with the vaccum thing too? i just got off the highway cruising at 80, and my vaccum was at -10, -20 at idle. this sound right?
Nate
Old Dec 28, 2004 | 12:47 PM
Mr. Sandog's Avatar
Nate
If this is what you saw when you let off the gas, then yes.
Old Dec 28, 2004 | 02:20 PM
NateZ's Avatar
No not when i let off, when i was cruising, it was on cruise control... -10. i thought it should be at zero at cruise? It's not making as much boost as it was yesterday, i think there might be a problem , leak or somthing somewere it's really wierd. any suggestions?
Nate
