Where is there a hole in the firewall? I need to pull a wire to the engine bay.
Old Jan 29, 2002 | 03:44 PM
FASTZ71's Avatar
Default Where is there a hole in the firewall? I need to pull a wire to the engine bay.
Almost dont with my nitrous kit and I need to wire a final wire from inside my cab to the solenoids and battery under the hood. Where should I pull this wire? any ideas?
Old Jan 29, 2002 | 04:27 PM
GREGGO's Avatar
Default Re: Where is there a hole in the firewall? I need to pull a wire to the engine bay.
There is a thick cluster of wires coming out of the fuse pannel under the hood going through the firewall next to the master cylinder. I folded a coathanger in half and ran it through grabbed the wire and looped and taped it to the hanger and pulled it back through. Worked for me.
Old Jan 29, 2002 | 05:11 PM
bdubb's Avatar
Thats the same one I used also. Helps to have two people there so you can have one inside on on in the engine bay to pull it through.
ARC
57
Feb 21, 2022 10:54 AM
bighouse
Sep 27, 2015 12:37 AM
MWRitter
Jul 27, 2015 09:41 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Suburban2500
Jul 14, 2015 02:10 AM
