Where to hook up tach on nbs
Old 09-19-2010, 06:31 PM
TOTM: June 2007
bgray's Avatar
Default Where to hook up tach on nbs
Just wondering where I run the tach wire to on my 99 nbs to hook up a aftermarket tach
Old 09-19-2010, 07:17 PM
ihdude's Avatar
It is the white wire behind the cluster
Old 09-19-2010, 08:11 PM
kbracing96's Avatar
Yep and you'll probable have to set the tach to 4cyl to get the right reading out of it.
Old 09-19-2010, 08:26 PM
TOTM: June 2007
bgray's Avatar
Thanks as always
Old 09-21-2010, 01:01 PM
moes04silverado's Avatar
confused??? whats that mean
Old 09-21-2010, 02:01 PM
JoeGibbSilverado's Avatar
tach has to be set on 4 banger mode, i think it is a white wire behind the cluster
Old 09-21-2010, 02:42 PM
kbracing96's Avatar
Most aftermarket tachs have a switch on the back for 4, 6 or 8 cylinders for normal ignition systems so they read right. The pulse count that these trucks use is the same as a 4 cylinder so you have to set that switch to 4cylinder mode
Old 09-21-2010, 08:01 PM
on the autometer tachs u have snip two wires on the back of the tach, i believe they are orange and brown, cant remember exactly
Old 09-21-2010, 09:32 PM
TOTM: June 2007
bgray's Avatar
Nothey have switches
Old 09-24-2010, 09:26 PM
TOTM: June 2007
bgray's Avatar
Switches set to 4cyl mode, Connected to the white(kinda beige) wire and works perfect.
thanks crew
Quick Reply: Where to hook up tach on nbs
