when does the 4.8 5spd crap out?
Old May 19, 2005 | 08:01 PM
Default when does the 4.8 5spd crap out?
approx wut HP/TRQ rating does the manual transmission blow up?
keep thinkin about running a custom turbo setup on my truck, i figure if STS can run 5psi non-IC i coudl run 7 psi Intercooled. than upgrade the fuel pump/injectors and run 9-10psi intercooled. im sure the bottom end can take it, dont think i'd have valve float problems if im still running the stock cam.
any one know?
Old May 19, 2005 | 08:29 PM
shandy294's Avatar
All I've heard is that it can't take much...don't know the numbers. It's only available with the 4.8,right?
Old May 19, 2005 | 08:38 PM
jdawg04 4.8's Avatar
iheard not much more then 400 whp but im just a newbie so i may be way off and yes it is only avalable in the 4.8
Old May 20, 2005 | 12:52 PM
I blew up two 5 speeds with the stock 4.8. If you put a turbo on your truck, kiss the tranny ( and rear) goodbye. However, it was rather easy to convert to a 700r4 ( built VERY strong of course) and the truck is much faster with the automatic. On street tires with the 5-speed, I couldn't get out of the 15's. With the 700r4 on street tires I run consistent 13.30's.
Old May 20, 2005 | 02:09 PM
litreddevil's Avatar
Banned
you could also go with a 6 speed out of a z28 are firebird. some one has already done this and they were very happy with the out come
Old May 20, 2005 | 02:15 PM
redaddiction's Avatar
I'd just go with a 6 speed also.
Old May 20, 2005 | 08:31 PM
i was thinkin about a 6speed from a z28, any how-to's on it? what all needs to be replaced?
maybe ill just buy a wrecked z28 or something and swap out the transmission and whatever else i need.
Old May 20, 2005 | 09:47 PM
LARRY01Z28's Avatar
go with the 6 speed.
TrendSetter
Nov 26, 2018 07:18 AM
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
