Wheels Question
Old Aug 6, 2004 | 11:38 AM
00blacktrailwagon's Avatar
Default Wheels Question
I was wondering if a 15 inch wheel will fit on a 2000 silverado? if so what do i need to do to the caliper?
Old Aug 6, 2004 | 11:45 AM
Scream's Avatar
MOOBIES Moderator
Not without grinding the hell out of the caliper. I would really suggest sticking with 16" rims or larger if you can.
Old Aug 6, 2004 | 02:33 PM
put the calipers in really cold water to make em shrink. then the 15's should fit fine Stick with 16's, I have 17's and they work pretty good, I had a problem with the brake caliper hitting the valve stem on the rims, but that was fixed immediately. BTW why do you want 15's??
Old Aug 6, 2004 | 04:49 PM
I justwanted to use the 15 to go drag racing and for soem slicks that i already have.
5.3Caprice
Nov 7, 2015 08:56 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
