What's the deal?
Old Oct 30, 2003 | 08:11 AM
jdpanero's Avatar
Default What's the deal?
I've got 2 problems that may or may not be related.
1. Truck acts like it has some KR going, but no real pattern. Sometimes when it fires up, it runs great. But always when I run hard for a while it feels like it retards. I had a O2 sensor code a while back, but it hasn't reappeared. When I run the HPP3 PowerTuning, I don't have any underpowering issues, but this isn't a viable option b/c it knocks a little in high rpms. Knock sensor, O2?
2. I've got a powertrain shudder at high speeds. It gets worse as I slow down. I serviced the tranny & trans case...Nothing at all. No codes. I'm thinking rear end, but haven't pulled off the diff cover. The way it feels when it slows is making me think I broke some teeth, worse on the one side.
Wondering if anyone's had some experience/suggestions. Thanks.
Old Oct 30, 2003 | 08:41 AM
Seeing Red Again's Avatar
I can't answer number 1, but for number two check your drive shafts and u-joints. A lift puts them at an angle where they wear u-joints faster and bind more often. My jeep did that back when it actually could run over 60 MPH, and it was due to the drive shaft angles, both front and rear.
Old Oct 30, 2003 | 10:07 AM
goshawk23's Avatar
Truck addict
try finding someone close to you that has autotap and see what is going on with problem #1. your o2 sensor might be going out and it just isn't ready to die yet.
Old Oct 30, 2003 | 11:17 AM
OBXMarine's Avatar
Here's a link with some good info for testing the O2 sensors:
http://www.autozone.com/servlet/UiBr...3d8004f602.jsp
Knock Sensor:
http://www.autozone.com/servlet/UiBr...3d8004f7b6.jsp
Old Oct 31, 2003 | 11:41 AM
jdpanero's Avatar
Thanks for the help guys. I'll check it out a little more in depth.
jscherbs
Mar 24, 2017 07:20 PM
vmaxpro
Sep 28, 2015 11:10 AM
Big_pimie
Sep 22, 2015 09:07 PM
03chevytruck
Sep 14, 2015 09:15 PM
