what would it take?
Old Feb 11, 2012 | 08:18 AM
darnie's Avatar
He has a 2005obd2 dodge 3500blue cummins 4diesel door long bed with the 5.9 6speed. I won't be able to keep up with his smoke even once he's done he should be pushing around 900hp plus or minus he's putting about 20-25g into the motor and having it built by industrial injection. Its gunna be pretty BA I'm just wanting to have fun with my truck ans I figure if I can smash on some gas trucks he can handle the diesel's. Like I said just trying to see what to do next and what's worth the money. I'm getting a dm 100 and wideband soon. Along with my stall so should be solid but I'm sure ill want more....
Old Feb 11, 2012 | 08:54 AM
AndysC3's Avatar
Most stock Lightnings are running low 14s here in Tucson. I ran a 13.7 here with my mods. Im going to the track today to see if I can get a PB. My truck weighs about 5200 with me in it. Some lower gears would be very beneficial with the 33s.
Old Feb 11, 2012 | 09:03 AM
darnie's Avatar
Ya my buddie just changed his gears. I got the frount drive shaft pulled for now so I can just do the rears. I live in Safford. So not to far... ill have to log in to check out ur mods...
Old Feb 11, 2012 | 01:46 PM
darnie's Avatar
in my case what would be the next mod to do after my stall?
Old Feb 11, 2012 | 02:09 PM
jrmchevyman's Avatar
After the new torque converter and gears then Heads, intake and boost is left or either nitrous lol.
Since you have an LM7 you could change it out for a TBSS or NNBS intake, the Fast intakes are too expensive IMO. Heads with the new intake would help out also..
As for a baller on a budget converter the Circle D 278mm would work fine for you, but if you wanted the best gains from a converter then look at a smaller diameter converter.
BTW FTI out of florida has a 278mm converter called the Street Brawler series for LS setups and they are a tad cheaper than Circle D. $339 for a FTI 3000 converter or $349 for a 3200 and its a 278mm just like circle D which is just a reworked TBSS stall. Both companies are awesome, but I just wanted to try and help you out and save a few bucks to put that money on other mods. The FTI is designed for the 400-500HP range. A lot of Florida drag racers use FTI they are built well.
Old Feb 11, 2012 | 02:33 PM
darnie's Avatar
ya i was gunna get a CIr-D stall but was also looking at a place in Phx called roarrunner. there about 300 ish for a stall but idk?
I wasnto do a intake swap as well and maybe have my heads worked. im not sure how much tho? and also what kinda gains would i see from that? JW
Old Feb 11, 2012 | 02:45 PM
You don't want to go too cheap on parts like the converter. IDK anything about that roadrunner company out of PHX. If you know of people running them without issues and they beat on them and hold up, then maybe consider them. If you don't know any personal experience from them then I would just stick with a known brand like Circle D or FTI.
Old Feb 11, 2012 | 03:43 PM
darnie's Avatar
Ya im pretty set on cir_d then maybe getting a intake and what not
Old Feb 11, 2012 | 05:40 PM
Beatdown Z's Avatar
Laid Back
For a stock trans, I'd keep an eye on the classifieds for a low mileage 3600+ rpm converter.
What gears are you planning on installing? If you plan on keeping those 33's, hopefully at least 4.56's. Then you can throw some short tires on it and have it be a real monster!
Greymatter04 said he lost power after switching to the newer style intake, just so you know.
Keep working on weight reduction as every little bit counts.
Old Feb 11, 2012 | 07:42 PM
darnie's Avatar
ya i been looking at gears too, ill see how the stall goes im looking at 3000-3200 and then i was thinking 4:30 gears but they dont make it for the frount
