What would cause this?
Old Sep 21, 2010 | 09:39 AM
blsnelling's Avatar
Default What would cause this?
These plugs came out of my trucks original 5.3. It has 78,000 miles and runs great. It does not smoke. 7 of the plugs were clean, but #7 had all these deposits on it.
Old Sep 21, 2010 | 09:43 AM
MikeGyver's Avatar
That's oil.
Old Sep 21, 2010 | 09:45 AM
blsnelling's Avatar
Originally Posted by MikeGyver
That's oil.
But how's it getting there? Rings, valve stem seals, valve guides.....?
Old Sep 21, 2010 | 09:57 AM
MikeGyver's Avatar
The only way that I know to distinguish between rings and valve guides/seals is when the smoke occurs. Smoke on startup = seals, smoke when decelerating = rings. In your case, I don't know what to do.
Old Sep 21, 2010 | 10:13 AM
blsnelling's Avatar
Wouldn't that be too much buildup to only be from start up?
Old Sep 21, 2010 | 10:47 AM
MikeGyver's Avatar
Not if it's been doing it for awhile. Do a leak down test, maybe you'll get lucky and hear a leak. I doubt it though, it would be too small.
Maybe it's time for that LS7 you've been thinking about.
Old Sep 21, 2010 | 10:51 AM
blsnelling's Avatar
This is the engine I just pulled from my truck and replaced with a built 6.0. It's going to be sold, but I've got to make sure it's right first.
Is there any way to test for rings/seals with the engine not in the vehicle? I have no provisions to turn it over fast enough to check compression.
Old Sep 21, 2010 | 10:55 AM
blsnelling's Avatar
OK, I'm reading about doing a leak down test now. I've not done one before. Sounds like what I need to do.
Old Sep 21, 2010 | 11:07 AM
blsnelling's Avatar
Harbor Freight has a dual guage tester for $40, LINK. I think I'll drop by this evening and pick one up.
