What supercharger would you suggest for a 5.3 tahoe?
Old Jun 10, 2003 | 02:05 PM
1SlowT/A's Avatar
Default Re: What supercharger would you suggest for a 5.3 tahoe?
Would towing uphills (example) be a problem with any of the superchargers mentioned? Does it put too much stress if in 4wd? Thanks. i appreciate everybodies feedback
Old Jun 10, 2003 | 10:12 PM
StupidFast's Avatar
ATI would not be my first choice for towing. I would go with a Whipple or Radix. As for rpm dependant, I make my max torque at 3500. It just depends on the setup. If you go ATI you will need a stall.
Old Jun 10, 2003 | 11:33 PM
BlownChevy's Avatar
blownerator
25 Year Member
Radix, Radix, Radix!
Old Jun 11, 2003 | 06:34 AM
parish8's Avatar
single digit dreamer
ATI for towing makes no sence at all, with my whipple(similar to radix) i can see 80% of my boost in overdrive before it downshifts, around 2000rpm. it is awsume for towing. my truck stays locked up in overdrive towing like it never did before. i think the ATI kit makes more sence for a drag racer where you will be runing it at 3000rpms and higher.
Old Jun 11, 2003 | 01:18 PM
1SlowT/A's Avatar
From what ive read and researched I think im going with the Radix supercharger. It seems like the most complete kit also(great for driveway installs).
Now how long will the 5.3 last with the stock pulley in the Radix kit? I dont really drive the truck too easy to begin with.
And last but not least.....Can you install and uninstall this unit with no signs of it ever being there? thanks again
Old Jun 11, 2003 | 02:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
The kit is great for installing in your own garage, very straight forward. I have quite a few miles on the truck wiht the stock 3.4 pully and have seen ZERO problems. I highly reccomend it. As for uninstalling it, there is not very many modifications made that can't be turned back to stock!! DO IT, you will not regret it.
Old Jun 11, 2003 | 06:28 PM
parish8's Avatar
the 5.3 will last ALOT longer than your tranny. i would expect to get over 100,000 miles out of that motor with the radix at the stock boost, these things are built tuff. if you get a real posi and toss on some slicks and beat the hell out of it your tranny could go away prety quickly.
Old Jun 14, 2003 | 07:56 PM
01Tahoetwinscrew's Avatar
My best e.t. with my '01 Tahoe 5.3L 4wd is 13.93@97.4 with a 2.04 60'. It weighs 5750lbs.
LCHEE
Oct 24, 2020 04:10 PM
Vash3233
Sep 22, 2019 01:18 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
