What Size Injectors?
Old Jul 30, 2007 | 07:43 AM
WAHUSKER's Avatar
10 Second Club
Default What Size Injectors?
I just installed a 6.0L into my Avalanche & I completely forgot about replacing the fuel injectors. I'm pretty sure the ones from my 5.3L won't be enough, especially since it has stage 2 heads & a Lingenfelter cam. What are you guys using? Would stock 6.0L inj's be enough? Who sells them on here?
Mark
Old Jul 30, 2007 | 07:49 AM
truckmann's Avatar
I think some 8.1L injectors will be enough (36# at truck fuel pressure) for N/A. Nelsons has them or ebay.
If you want a little extra injector the 8.1 Marine injectors are rated for 42# and are also a direct fit.
Old Jul 30, 2007 | 09:31 AM
Tootall's Avatar
Originally Posted by WAHUSKER
. . . Would stock 6.0L inj's be enough? Who sells them on here?
4.8, 5.3, 6.0 are all the same size
Old Jul 30, 2007 | 10:55 AM
zippy's Avatar
You need to see if your truck had the flex fuel 5.3L in it. If it did, you have more than enough injector. If not, find some L18 or marine 8.1L injectors.
Old Jul 30, 2007 | 12:52 PM
truckmann's Avatar
Was flexfuel available on an 03 model???
Old Jul 30, 2007 | 01:30 PM
zippy's Avatar
It was available in 03', I'm just not sure if it was available on the Avalanche or not.
Old Jul 30, 2007 | 03:43 PM
WAHUSKER's Avatar
10 Second Club
So that could mean they'll be OK. But if they are only 28s, then I doubt it. The 6.6L in my TA before the blower was undernourished with 28s & perfect with 42s....looks like the Delphi 42s that Nelson sells might be the answer. Thanks all!
Old Jul 30, 2007 | 04:37 PM
ridnlow's Avatar
Im running 8.1 truck injectors 31lb's.. I usually see 65-70% duty cycle..
Old Jul 30, 2007 | 04:40 PM
zippy's Avatar
Personally that's probably what I'd go with. They idle like a stock injector and you won't run out of injector with them.
Old Jul 30, 2007 | 06:48 PM
truckmann's Avatar
If the price isn't a problem I think the 42's are the best choice wish I could afford some.
Stainless Works
13
Nov 5, 2015 03:31 PM
WICK3DxGATA
Aug 31, 2015 07:21 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
