What is required to go returnless?
Old Jan 12, 2012 | 10:28 PM
slammedsilvy's Avatar
Default What is required to go returnless?
Don't flame me guys, I've read countless threads, but still struggle to grasp this.
I have an 07 new body style, so an 87 mm returnless. I understand it would take a fuel pressure regulator, and a line returning to the tank. Do you tie the fuel rails together and then to the regulator? What does the return line go to at the tank? Is there a diagram somewhere I've missed?
Thanks!
Old Jan 13, 2012 | 10:27 AM
Are you wanting to go to a return style fuel system for some reason since the truck is returnless.
A real pita to go to a full return style system due to the piping of your new truck.
Or are you simply trying to change fuel rails and go to a set that are set up for return.
little more information and we can help you.
Old Jan 13, 2012 | 10:49 AM
neilownz's Avatar
What he said. We need to know the why...
Old Jan 13, 2012 | 12:52 PM
Gadgetized's Avatar
A returnless system still has a regulator, however it is mounted inside the tank.
A return style has the regulator on the fuel rail, and a return line running back to the tank.
If you wanted to make your system have a return line, you would need to get rid of the in tank regulator, run a return line through the top of the sending unit, run a return line to where you want the regulator, and mount a regulator where you want it, usually by the fuel rail.
Old Jan 13, 2012 | 12:58 PM
I just keep reading that return style can only support so much horsepower, so some people convert their returnless over to return with a couple pumps in tank. I don't plan on making the power needed to convert, just trying to understand.
Gadgetized summed up what I was looking for pretty much.
Old Jan 13, 2012 | 01:49 PM
BlackGMC's Avatar
Resident Retard
Everything i have read is the opposite...
My future plans are to add a surge tank... Keep the returnless intank pump feeding a 1-2 gallon surge tank, then add a big external pump to the surge tank feeding the rails.... So the surge tank and foward will be return style... i hate the returnless setups... All the ones i have seen have a PSI drop at WOT, which GM says is acceptable.. I hate it...
Vortec350ss
Oct 10, 2015 09:11 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
03chevytruck
Sep 14, 2015 09:15 PM
chevstang421
Sep 10, 2015 09:16 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
