what is needed
Considering your truck is an 00, you should get a new timing chain. Don't forget about all the gaskets and crank bolt along with some hardnened pushrods.
Originally Posted by chapita
what parts are needed for the 2001 zo6 cam swap just the cam and springs right or do i need more
Well hell, if you're going to do the chain, may as well get a LS6 ported oil pump also. They are a PITA, but you'll already be most of the way there to do the chain - an extra 5 min to slide in the new pump at that point. Just be sure to get a new o-ring seal with it from a dealership.
well my truck just barely hit 40k and i don't use it much but i want it to be drivable and i want to keep that sleeper look and sound (because i've been there and done that with the looks and sound thats only gets the cops attention) i guess i will get the cam, springs, maybe the timing chain, and all the gaskets seals and fluids thanks guys for your help in the mean time i am going back to getting my transmission built cause theres no use for all that power if you only have 2 gears
