what is needed
Old Feb 17, 2006 | 10:26 PM
chapita's Avatar
Default what is needed
what parts are needed for the 2001 zo6 cam swap just the cam and springs right or do i need more
Old Feb 17, 2006 | 10:40 PM
I'd replace the timing chain while I had thing apart,a slack timing chain can cost you a lot of power.
Old Feb 18, 2006 | 12:47 AM
FILE's Avatar
Considering your truck is an 00, you should get a new timing chain. Don't forget about all the gaskets and crank bolt along with some hardnened pushrods.
Old Feb 18, 2006 | 01:51 AM
Well hell, if you're going to do the chain, may as well get a LS6 ported oil pump also. They are a PITA, but you'll already be most of the way there to do the chain - an extra 5 min to slide in the new pump at that point. Just be sure to get a new o-ring seal with it from a dealership.
Old Feb 18, 2006 | 10:13 AM
v8
17,16,15,14,13,12,11 Drvr
http://www.ls1howto.com/ here this will help you
Old Feb 18, 2006 | 01:12 PM
98TAauto's Avatar
ls2 timing chain if your stocker is slack
ls6 ported pump if you have alotta miles on your motor
crank seal
water pump gaskets
crank bolt
cheap oil to flush motor
coolant
Old Feb 18, 2006 | 03:34 PM
chapita's Avatar
is that it ??
Old Feb 18, 2006 | 03:45 PM
98TAauto's Avatar
cam lube helps also
if you are changing the springs then you need a air compressor to hold the valves up of coarse..
Old Feb 18, 2006 | 03:50 PM
Dock Rocker's Avatar
I think that if you are there and replacing all of that stuff you should but on a blower or something
Old Feb 18, 2006 | 04:00 PM
chapita's Avatar
Talking
well my truck just barely hit 40k and i don't use it much but i want it to be drivable and i want to keep that sleeper look and sound (because i've been there and done that with the looks and sound thats only gets the cops attention) i guess i will get the cam, springs, maybe the timing chain, and all the gaskets seals and fluids thanks guys for your help in the mean time i am going back to getting my transmission built cause theres no use for all that power if you only have 2 gears
