What Muffler to Use Stock Pipes?
Old Aug 5, 2005 | 10:09 AM
dug's Avatar
dug
Banned
Default What Muffler to Use Stock Pipes?
I just want to change the muffler on my truck and keep the existing piping. Do I need a muffler with offset in and offset out in order to use the existing exhaust?
Old Aug 5, 2005 | 10:13 AM
3" center in/3" offset out.
Old Aug 5, 2005 | 10:16 AM
Fogle07's Avatar
i got a magnaflow that will work on it. for sale
Old Aug 5, 2005 | 10:53 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mine were center/center on my other dynomax mufflers. Also there are alot of straight through mufflers too.
Old Aug 5, 2005 | 11:07 AM
dug's Avatar
dug
Banned
Is there a easy way to run true duals from the cats back? The stock ypipe looks like its 2.5" diameter.
Old Aug 5, 2005 | 11:11 AM
1slow01Z71's Avatar
Yeah I guess you would call it easy driver side pipe comes around under the tranny tailshaft or over the top since you have a 2wd then the just run next to each other where the factory pipe is to whatever kind of exit you want. I ran dual 2.5" the factory size is 2.75" get an x-pipe while you are at it.
Old Aug 5, 2005 | 11:14 AM
white1's Avatar
I was going to say that too, the factory size is 2.75, so if all you do is swap mufflers you need 3"
Old Aug 5, 2005 | 07:05 PM
paramediclane's Avatar
fogle04, what are you asking for the muffler, and why are you getting rid of it?
askkmb
Jul 18, 2015 09:02 PM
Chiphead
Jul 13, 2015 10:16 PM
Suburban2500
Jul 13, 2015 09:57 AM
Moto733
Jul 12, 2015 10:25 PM
kdw8888
Jul 9, 2015 10:52 PM
