what lt's are you runnin
Old Mar 28, 2005 | 04:17 PM
  #31
skindog39's Avatar
you will LOVE the pacesetters...guaranteed
Old Mar 28, 2005 | 05:08 PM
  #32
2000SIERRA's Avatar
When are you suppose to get yours 2000sierra. The t-bars dont really look like they will interfere but we will find out soon but not soon enough. Ill let ya'll know how it works out on my truck ill take some pics and make a new thread.
Cody
I sent them the money the other day, so however long it takes to ship them. I'm not so much worried about the t-bars on my truck, I'm worried about the compression struts that are bolted to the tranny crossmember.
Old Mar 28, 2005 | 05:17 PM
  #33
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What are you calling the compression struts? I looked under my truck and I dont see what you could be calling that. Also are my A-arms suppose to be sitting on the bump stops when its on level ground I noticed that while i was looking under the truck? Also do anyone think that the length of the pacesetters will push the cats too far back to where the exhaust wont be able to make the bend before the transmission crossmember. I have true duals not a y-pipe so this is a little bit of an issue.
Old Mar 28, 2005 | 05:30 PM
  #34
2000SIERRA's Avatar
I have a 10" lift kit on my truck, which is why my front driveshaft or t-bars will be in the way, they are 10" lower than stock. The compression struts are part of the lift, they connect the rear crossmember to the tranny crossmember. I had the truck on the lift and from the measurments I read about, they come about 8" from the front of the trans crossmember. I plan on getting dual e-cutouts, highflow cats and all new piping made, but I think I might have to run the piping under the trans support instead of through it like the stock is. Heres a pic of my setup........
There you can see the struts bolted to the trans crossmember, and to the right the stock exhaust running over the trans support.
Old Mar 28, 2005 | 05:32 PM
  #35
2000SIERRA's Avatar
Also, your a-arms should not be sitting on the bumpstops, try cranking your t-bars a little bit
Old Mar 28, 2005 | 06:09 PM
  #36
1slow01Z71's Avatar
They havent ever been messed with to my knowledge I guess it is just old age and my driving habits offroad . Anybody know how much they bumpstops should be off the a-arm. By the way sweet ride 2000sierra wish I had the $$$ to get that on my truck.
Thanks, Cody
Old Mar 28, 2005 | 10:30 PM
  #37
1slow01Z71's Avatar
Guess not
Old Mar 28, 2005 | 10:52 PM
  #38
2000SIERRA's Avatar
Thanks, Cody
They may not have been messed with, my bars started to sag after the years. Here is a link to alot of info. about t-bars.
http://www.offroad-tech.com/tech/tb401/
Blackrat48
Aug 4, 2015 09:52 AM
JT-bo
Jan 10, 2006 02:52 PM
No. Its Not A Hemi
Oct 4, 2005 12:48 AM
02sierraz71_5.3
Mar 31, 2005 10:19 AM
BurntOrangeSierra01
Sep 29, 2004 11:29 PM
