what injectors will I need?
Old Mar 5, 2009 | 02:23 PM
lsx10's Avatar
Default what injectors will I need?
I have a 6.0 with cnc'd 243 heads, tr224 with yt1.8s, 10.6:1 compression, ls6 intake, and headers.
I was planning on running 8.1s with the truck intake, but since I picked up this ls6 intake i need to find another rout. the only other upgrade this engine will have is a 150ish shot and maybe a fast 90/90.
this is the first fuel injected engine i've upgraded so I have no clue what will be needed.
Thanks
Greg
Old Mar 5, 2009 | 02:40 PM
Gordy M's Avatar
Were you talking 8.1 marine or standard 8.1, the marine versions flow 44lb at 4 bar, should hold what your planning for and a few track shots of NO2 thrown in. Their good for Radix to use in a SC car.
Old Mar 5, 2009 | 02:54 PM
Mangled03gmc's Avatar
Baltimore Whore
42-44's should suffice on the 6.0
Old Mar 5, 2009 | 03:17 PM
lsx10's Avatar
I thought you couldn't use 8.1's with the ls6 intake and rails?
I found a caldulator that said I should have 40-42lb-ers
can anyone recommend a good injector?
Old Mar 5, 2009 | 04:20 PM
sickREDsierra's Avatar
racetronix makes some nice pieces, as dose Delphi.
i run a delphi 44, which will be more than enough for you, especially if your nitrous is wet. they are only at high 80's IDC with my dry shot.
Old Mar 5, 2009 | 11:09 PM
lsx10's Avatar
thanks
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
