What injectors size
Old Apr 24, 2005 | 10:20 AM
bourbeaugmcx's Avatar
Default What injectors size
could some one help me on my fuel issue. everything is listed in my info. but to start i'm currently running FMU and i want more boost and a small nitrous shot. i'll be getting out of high school soon and a ton of money will coming my way(from family), so want should i run for injectors to support like 600 flywheel horsepower, i'm thinking something like 10 psi and then 30-50 shot for something along the line of intercooling my vortech s/c, so i need a fuel system to support that., how far do u guys think i'm pushing it so far (stock fuel system)?
Old Apr 24, 2005 | 10:28 AM
greentahoe's Avatar
You would probably be OK with 42# injectors. Either way you need to get rid of the FMU ASAP. You would need a wet nitrous kit though. Im going to go with 60# injectors for the new setup. With those you need to modify your fuel rails and use pigtails I believe.
Old Apr 24, 2005 | 10:40 AM
For a 600rwhp FI motor you'll need bigger than a 42#injector,I'd go with a 60#shortie.
Old Apr 24, 2005 | 11:15 AM
what brand are the 60# shorties(give me a link) and what would i have to do to make them fit, more details please? oh, and 600hp flywheel is where i would stop...maybe
thanks,
-ryan
Old Apr 24, 2005 | 11:49 AM
i found some 60# shorties on racetronix and i wanted to know what i need to do to get them to fit?....everyone put in there input
Old Apr 24, 2005 | 12:01 PM
The 57s I'm running required a different connector and a spacer for the fuel rail.The shorties won't need a spacer,I think the connector will be the same[not sure].If you have to change the connector they get a little pricey.Other than that ,just scale the injectors and go.
Old Apr 24, 2005 | 12:12 PM
thanks whitt1, so does anyone know about the connectors
-ryan
Old Apr 24, 2005 | 01:42 PM
CHarris's Avatar
You can get them from Speartech. The "Speartech kicks ***" post has the info.
Old Apr 24, 2005 | 08:34 PM
and about them connectors????
Stainless Works
13
Nov 5, 2015 03:31 PM
WICK3DxGATA
Aug 31, 2015 07:21 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
