what heads do i have
Old Aug 11, 2008 | 02:55 PM
454navyss's Avatar
Default what heads do i have
what heads came on a 2002 5.3 silverado? and would 241s be a step up? my truck has bolt ons and hopefully soon it will have a 2002 ls6 cam and yellow valve springs and was thinking about doing a head swap (with a little machine work) at the same time.
Old Aug 11, 2008 | 02:59 PM
Mangled03gmc's Avatar
Baltimore Whore
706's or 862's Try to get ya a set of 243 heads instead of the 241's but
John
Old Aug 11, 2008 | 03:05 PM
454navyss's Avatar
what are the differences? do the ls6 heads have a number?
Old Aug 11, 2008 | 03:15 PM
skeet's Avatar
check the back of head if you can, if there 706 castings i would get them polished and ported, i gotten some from patriot (stage 2's ) and theyre a nice set of heads for a 5.. why an ls6 cam? i'd find a 220 cam to throw in there..those springs would work perfect.. if not mistaken using a set of 6.0 heads (243) you would need to have them milled..
Old Aug 11, 2008 | 03:19 PM
Baltimore Whore
6.0 heads are 317's . Ls6's are the 243's. Have them P&P and milled for a nice hp, comp bump.
John
Old Aug 11, 2008 | 03:22 PM
454navyss's Avatar
mine say 706 on them but i would like to do the swap in one day since it is my DD. i figured i would get an ls6 cam because i can get one for around $100 and its not too big but it is bigger than stock.
Old Aug 11, 2008 | 03:23 PM
454navyss's Avatar
i was thinking 243s were ls6 heads but i didnt want to open my mouth and look dumb
Old Aug 11, 2008 | 03:37 PM
krambo's Avatar
799's are also LS6 heads.
Old Aug 11, 2008 | 05:23 PM
skeet's Avatar
thanks mangled, 454 i stand corrected
Old Aug 11, 2008 | 08:52 PM
Mighty Whitey's Avatar
12 Second Club
you can get a set of 243's of any LS2, they might be easier to find than the LS6 243's.
as they have different valves. same flow tho...
