what heads for 4.8
Old Jan 21, 2005 | 03:35 PM
BlackSilver's Avatar
Originally Posted by Badzracing
If you want to go the "cheap" route, a set of ls1 heads would be sufficient. The have bigger combustion chambers and valves then the 4.8/5.3 heads. Unless you are going to run a hell of alot of boost, I think 6.0 heads would be too big ( static compression would be WAY too low and you'd have NO bottom end power).IMO.
what would you consider to be a "hell of a lot of boost"?
Old Jan 21, 2005 | 03:53 PM
Sport Side's Avatar
Ive read that the combustion chambers are bigger than the piston bore, thus overlapping it.
Yeah guys...keep this in mind when using larger engine cylinder heads
Old Jan 21, 2005 | 06:20 PM
hefdaddy007's Avatar
yeah i'm looking at droping my compression to low. i want some botom end power. i'm just looking at flow good flow. i'm looking at like 10psi or so my goal is just 400rwhp daily driven and i think it can do it. we'll see. but i know if i drop the compression to low then it will just suck. like a honda with a t88 or something just kinda point less at the bottom. just want good enough flow for the t4/to4r.
Old Jan 21, 2005 | 06:26 PM
so ls1 head will be fine?? how about a set off of a 01 ws6 would that be good. would i need to get diffrent push rods or any thing. how about head gasket would i just use stock one or ls1 head gaskets i would think ls1 head gasket would leave a gao between the head and deck. wich might could be bad. any thought??
Dan Neumann
11
Aug 7, 2022 09:06 AM
chopperloco
Jul 10, 2016 10:45 PM
JordanH
Aug 8, 2015 07:59 PM
bbowerman
Jul 26, 2015 10:57 PM
