What to expect
Old Feb 6, 2014 | 02:56 PM
03sierraslt's Avatar
Originally Posted by custm2500
Te K+N needs to be returned and simply buy airaid's MIT. It is much cheaper and makes more power. Blackbear has dyno numbers to validate it.
Other then that you have a good plan! The one thing you are missing is a converter and cooler. A converter should be first on your list in my opinon. It helps a stock engine a lot and makes massive gains with a converter. .3-.5 stock and .5+ easily with a cam.
The 100 shot is a for sure in my opinion. A 100 shot with a bit of inteligents can be ran for ever without any issue. Unless boosting I don't know why anyone who is drag racing a budget build wouldn't run at least a 100 shot.
Intelligence
oh the irony
Old Feb 6, 2014 | 03:48 PM
calboi's Avatar
lol i asked the question so i was saying anything
Old Feb 6, 2014 | 04:08 PM
graysilverado5.3's Avatar
I went 13.3@104 1.9x 60ft with almost same mods and with a TB converter, then 11.8@114 with a 150 shot on 28" slicks. Added tbss intake, 3600 converter and asp pulley, dropped it down to 13.0 then added worked heads and my best was a 12.8 with out taking off my tonneau cover and in hotter weather than previous runs. Oh and had 4.10 gears, and the high lift version of the cam.
Old Feb 6, 2014 | 04:21 PM
calboi's Avatar
damn 11.8 at 114 that thing got up out the hole quick huh... sounds like a decent lil setup and im reading more and more about folks spraying 150-200 on these i may just go with the 150 also..
Old Feb 6, 2014 | 04:24 PM
calboi's Avatar
was that off a footbrake gray??? thinking of getting a trans brake also just dont know if it would help i know most races are won within the first 60' so im trying to the most stuff i can to get it off the line with the most torque and not spin to much...ima invest in a stall but only after the warranty runs out on my tranny thats the main reason i havent gotten one already
Old Feb 6, 2014 | 04:40 PM
Yes, off the the footbrake. 60ft with the 150 off the line was a 1.62. Im sure it could of gone maybe mid 11's with the other mods I added later. Buddy had the low lift version of the cam, and I belive he hit a 11.7@112.
Old Feb 6, 2014 | 05:42 PM
calboi's Avatar
I'd be very happy with 11.7 at 150 with this setup but then I'd prolly buy a stall and bigger cam lol
Old Feb 7, 2014 | 09:12 AM
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by calboi
when looking at the stalls what would be a good for my truck...i also drive this thing alot outta town.
any stall that is a lock up converter(99% of them are) is fine for out of town.
I drove my 3200 stall from NW ohio through PA's hills and mountains to DC and back.
Old Feb 7, 2014 | 10:00 AM
calboi's Avatar
im thinking a 3000-3200 may be in the lines as to what i will be needing and looking for prolly i changed the nitrous in the tune with blackbear before they tuned so i can shot the 150 to it everything ive seen shows i should be safe there for little i will be spraying it.
Old Feb 7, 2014 | 10:01 AM
calboi's Avatar
im hoping to get it down to low 13's on motoro then put the 150 on it
FlowmasterMufflers
Nov 24, 2015 01:00 PM
bearden86
26
Nov 15, 2015 03:58 PM
zblee
Sep 17, 2015 07:58 AM
FormulaZR
Sep 14, 2015 05:23 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
