what engine???
Old Oct 21, 2007 | 07:07 PM
andrew383's Avatar
traveling mod
Default what engine???
i have an 07 classic 1500 5.3 flex. what engine is it? ls1 ls2?????
Old Oct 21, 2007 | 07:23 PM
nightrunner's Avatar
Mr. Obvious
it is a variation of the LM7 or L33, it has its own RPO, i just dont know what it is
Old Oct 21, 2007 | 07:25 PM
SmokedSierra01's Avatar
They are based off of the same block if I am not mistaken, but the 5.3 in your vehicle is not classified as an LS1 or LS2
Old Oct 21, 2007 | 07:53 PM
andrew383's Avatar
traveling mod
so when buying parts.. will ls1/ls2/ls6 parts fit???? i was looking at the lsx intake from f.a.s.t.,how much pita is it to install??? is it pure plug n play?? it looks different than the intake thats on my truck now so i was thinkin it wasnt
Old Oct 21, 2007 | 08:21 PM
Mr. Obvious
yes ls1, ls2, ls6, 5.3, 4.8, 6.0, those parts fit your truck
the FAST LSX intake is NOT plugnplay on trucks, it requires car-style fuel rails/injectors, a different water pump, that goes for any car-style intake on the trucks
Old Oct 21, 2007 | 08:24 PM
andrew383's Avatar
traveling mod
dang that sucks.... does anybody make a performance intake for our trucks??
Old Oct 21, 2007 | 08:27 PM
Mr. Obvious
not a direct swap for the intake manifold, no
however the intake manifold is one of the last things you will need to swap
Old Oct 21, 2007 | 08:33 PM
andrew383's Avatar
traveling mod
so whats the difference between the ls's and truck motors if parts are interchangable?i know the car motors make more power via diff cam/head work.
Old Oct 22, 2007 | 02:09 PM
ForcedTQ's Avatar
Post
I believe the engine code is L59, it's a Generation III 5.3 small block similar to the LM7 (except for the fueling system).
Old Oct 22, 2007 | 10:22 PM
andrew383's Avatar
traveling mod
can any gains be had from parts off the new 6.2??
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
