What else needed for my turbo build? Aiming for 650rwhp
Hey guys, every single opinion, idea or advice is more than welcome!!
My current upgrades are on my sig.. Plus a TBSS intake and throttle body I just bought..
I ordered a stage 3 trick turbo kit with upgraded intercooler.
Already have ARP bolts, and will get LS9 head gaskets..
I am aiming for 650rwhp..
What injectors should I get?
Water/meth kit should I buy?
What Exhaust should I order?
Boost controller?
What else is needed to get closer to my goals?
Dont worry about tranny, I will get a built 4L80e..
Also, do you all think is worth the cam swap from my 220-112 to a triple 12??
Thanks to all in advance!!
Boost controller?
80lbs LS3 style from FIC will work great.
take your pick they are all about the same.
You will want to have a custom downpipe back setup. I like magnaflow mufflers. Otherwise you can pick what you like.
Boost controller?
The eboost is a nice reasonable model.
A real good custom live tune from a very good tuner.
No. It will only make a small difference. If you get to the point where you want to pick up that last tenth or something then do it.
Boost controller?
on my setup i gained about 17hp for 1psi
so 15psi you're looking at 550
plus you will need meth or switch to e85
even at that you may be past your turbo's efficiency limits, any more boost and you're just blowing hot air
