What else needed for my turbo build? Aiming for 650rwhp
Old Nov 13, 2013 | 11:11 PM
Cammed4ever's Avatar
Default What else needed for my turbo build? Aiming for 650rwhp
Hey guys, every single opinion, idea or advice is more than welcome!!
My current upgrades are on my sig.. Plus a TBSS intake and throttle body I just bought..
I ordered a stage 3 trick turbo kit with upgraded intercooler.
Already have ARP bolts, and will get LS9 head gaskets..
I am aiming for 650rwhp..
What injectors should I get?
Water/meth kit should I buy?
What Exhaust should I order?
Boost controller?
What else is needed to get closer to my goals?
Dont worry about tranny, I will get a built 4L80e..
Also, do you all think is worth the cam swap from my 220-112 to a triple 12??
Thanks to all in advance!!
Old Nov 13, 2013 | 11:20 PM
gamble686's Avatar
80lbs LS3 style from FIC will work great.
take your pick they are all about the same.
You will want to have a custom downpipe back setup. I like magnaflow mufflers. Otherwise you can pick what you like.
Boost controller?
The eboost is a nice reasonable model.
A real good custom live tune from a very good tuner.
No. It will only make a small difference. If you get to the point where you want to pick up that last tenth or something then do it.
Hope that helps.
Old Nov 13, 2013 | 11:27 PM
Awesome!!!! Thanks man!!! How does the downpipe need to be?? I like magnaflow too! Does it need to be 4"??
What psi should I be running to get my 5.3 to 650rwhp??
Old Nov 14, 2013 | 06:58 AM
Chevy_King1500's Avatar
18-20 psi
Figure 15psi will double your engines output
Old Nov 14, 2013 | 07:00 AM
03sierraslt's Avatar
Meth kit- alky control is the only one with stainless braided lines and the ability to run 100% meth so not all are created equal.
Old Nov 14, 2013 | 07:32 AM
18-20?? Thats a lot for a stock 5.3 right??
Nic D will do my tunning..
Old Nov 14, 2013 | 07:46 AM
Yes that's allot.
Old Nov 14, 2013 | 08:36 AM
15psi is about the max on the "safe" side right?
Where will 15psi will put me in (hp)??
Old Nov 14, 2013 | 09:39 AM
on my setup i gained about 17hp for 1psi
so 15psi you're looking at 550
plus you will need meth or switch to e85
even at that you may be past your turbo's efficiency limits, any more boost and you're just blowing hot air
ZONES89RS
21
Sep 24, 2015 05:58 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Cowboy17
Jul 9, 2015 06:18 PM
Aboss
Jul 9, 2015 10:28 AM
