what do the ppl think?
Old Aug 31, 2010 | 06:56 PM
youngbuck's Avatar
Default what do the ppl think?
im gettin my truck back from swappin the 6.0 in soon an my next move is a cam n cutouts. goin dhm on the cutouts cuz i heard good things bout them. will i need to upgrade injectors ? i cant decide on the cam tho so im askin for help. thinkin of the tsp 224r 224/224 .581/.581 on 110 lsa, the tsp 228r 228/228 .588/.588 on 111 lsa. or the tsp torquer.v2 232/234 .595/.598 on 111 lsa. truck is a single cab z71 with the stock 3.42s its my dd not sure my exact tire size but i have the ss rims so w.e tht size is. have a transgo shift kit 4l80 tanny with 3200-3600 stall, truck is my dd so streetabilty is the main thing, dont get out to the track much but would like to roast some stangs on the street . thanks in advance any imput y or y not with the cams an if u think a diiff one would b better dont hesitate to tell me
Old Aug 31, 2010 | 07:08 PM
zero2sixT's Avatar
You wont need bigger injectors. Torquer V2, don't be scared.
Old Aug 31, 2010 | 07:53 PM
iamkeniff's Avatar
if you run that Torquer V2 you'll need 4:10s with a 3600 converter thats a big *** cam for a stock head 6.0
i would run a 224/228 .585.588 112+2 with a 3400 converter with 3:90/4:10s
i guess you can say i feel you can get more outta the smaller cam vs the "biggest" you see.
Old Aug 31, 2010 | 09:17 PM
im runnin the v2 in my ls1 in my ecsb and i love it. would be a nice cam in a 6.0. i also have 4.10s and a PI 3600. im puting on PRC stg 2.5 5.3 heads this weekend. should really wake it up!!
Old Sep 1, 2010 | 05:50 AM
iamkeniff's Avatar
told ya
06tx4.8 that thing is going to LOVE those heads. are they stock deck or have they been milled?
Old Sep 1, 2010 | 05:53 AM
iamkeniff's Avatar
that's your main problem. i dont think a huge cam is that great for a DD, but its all in what you can stand to drive. i have a 228/236 112+2 in my CC with a 3600/4:10 combo...i can stand it, but i promise you, it gets annoying. but like you said when you whip up on a sports car, it just makes you even more happy to have it
id contact Pat G and see what he says to run imo. my next cam will be a Pat G cam with EPS lobes. i will get the MOST outta this 6.2/3600/4:10 combo
Old Sep 1, 2010 | 09:23 AM
zero2sixT's Avatar
He doesn't have a land barge crewcab. Its a single cab 4x4. I don't even know why you'd mention stock heads with that cam. 317s are good stock heads, they aren't really the limiting factor on the engine.
OP,
You won't have any daily problems with a low 230s cam in a 6.0. A V2 is not a big cam for that engine. I just stuck a custom low 230s cam in my lq9. In a few days, its going in my reg cab, 2wd. My goal is a nice streetable truck w/ a/c, that puts down ~400 rwhp.
Another thing, it's not required to run an 80e behind a cammed 6.0. A built 60e will handle the power. The 80e will work great, and you can beat the hell out of it and have confidence your transmission will hold up. It just has a taller 1st gear ratio than the 60e. It may be a little doggish off the line with the 3.42s. Id still run them before I swapped to a shorter ratio. Just to see if I liked it before I dropped cash on a gear swap. You'd be able to leave a lot harder with the 3.42s over a lower gear b/c of traction issues.
I'd also look into a TBSS swap. Its a nice mod, that is relatively cheap to do.
Old Sep 1, 2010 | 09:57 AM
youngbuck's Avatar
OP,
That's what im looking for 400rwhp an mean as hell sounding An my thoughts exactly on the gear. May switch them but ima wait an see 1st. Jus want the best sounding/ pulling cam for my setup without changing a bunch of stuff.
Old Sep 1, 2010 | 11:22 AM
Dezert1500's Avatar
I couldn't see that cam with 11* of overlap on the OP's combo, 3.42's, 4L80E, and 3200-3600 street enjoyable, but that's just me....
Old Sep 1, 2010 | 11:41 AM
zero2sixT's Avatar
Define street enjoyable. And yeah, like I posted above, I'd run a built 60e. But, it will still run good on the street with a 80e, just slow him down off the line. Anyway, all he said was the converter was 3200-3600. I know you know that isn't the only characteristic of a stall converter. 3.42s might be an issue. Why not just run them to see how it does? Gears can be swapped anytime.
A custom cam with some advance ground in might be a better choice than the V2. But I'd run a low 230s duration cam in a DD rcsb 6.0 all day long.
