What do i need?
Old Oct 23, 2009 | 08:18 PM
Robertp's Avatar
Default What do i need?
i want my truck to run mid to high 13's and still be reliable for everyday driving. first off is this possible. i have built many diesels to run 12's for everyday driving but never a gas motor.
the truck in my sig is what im trying to make this happen on. right now it has, no tune in it at all. i plan on a Blackbear tune and a set of 8.1 marine injectors. what else am i going to need?
Thanks
Robert
Old Oct 23, 2009 | 08:54 PM
JKmotorsports's Avatar
So it's boosted with the stock pcm tune? A tune will make a huge difference. It will also make it a lot safer to drive.
Old Oct 23, 2009 | 11:00 PM
MikeGyver's Avatar
How can you even drive it with a supercharger, stock injectors, and stock tune? You are going to ruin it. When I had a stock LQ4, I had 42 lb injectors, fuel pump, intercooler and tune. I ran 13.2 @ 104 mph. I think that was at 11 psi.
Old Oct 24, 2009 | 06:39 AM
Robertp's Avatar
i bought the truck this way, about a month ago. it only has 63,000 miles on it and the procharger has been on it for about 15,000. this truck has never seen the race track and wont until i get it tuned right.
Old Oct 24, 2009 | 07:21 AM
sureshot's Avatar
What level of boost will you be running and what gears are you running?
Old Oct 24, 2009 | 09:27 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
with any boost the fueling will need to be enriched. Do you have a wideband or logging capability?
With tuning you should be able to run 13's fairly easy with the right supporting mods.
Old Oct 24, 2009 | 10:52 AM
sureshot's Avatar
With the D1 on the 6.0, 42# injectors won't keep up, you need to get 60# injectors. You'll also need to upgrade your fuel pump. With the 35" tires, I would run at least a 4.10 gear. After that, get a wideband and proper tune and then you're good to go.
Old Oct 24, 2009 | 02:11 PM
Robertp's Avatar
right now i can see 9lbs of boost. the truck has 4.10's in it.
yes a wideband is on the list of things to do before i get the blackbear tune.
the truck has the whole procharger kit. it already has an inline pump that works with the one in the tank. it also has a FMU mounted to the fire wall.
so your saying get the 60lb injectors instead of the marine 8.1's?
all of this info is great. thanks fellas. i want the truck to be right, i also want to get all of the things i need to do done before i get it tuned that way i only have to do that once. and i know its right.
Old Oct 24, 2009 | 03:41 PM
sureshot's Avatar
Yeah, get the 60's. I know sharpshooter was maxing his 42's out when he had his procharger on the 5.3. When he put the cammed 6.0 in, he put 60's in.
Old Oct 25, 2009 | 02:00 PM
Robertp's Avatar
ok so. all i need to make this happen is a wideband gauge, 60 lb injectors and a tune? hmmm. well then maybe i want to go faster than that?
with the 4L80E hold this type of power?
