What can I use off my 4.8?
Old Jul 28, 2008 | 01:22 PM
jdawg04 4.8's Avatar
Default What can I use off my 4.8?
If I were to get a 6.0 long block what would be transferable over from a complete 4.8?
Old Jul 28, 2008 | 01:33 PM
Tootall's Avatar
if you'd do a little searching. . . . everything, but the long block, other than that everything swaps over.
now if it's a 99-00 block, then stay away from it.
Old Jul 28, 2008 | 06:16 PM
nightrunner's Avatar
Mr. Obvious
correct everything but the short block will swap over. you will want to stay with the complete 6.0 longblock but if you really had to you could use the 4.8 heads for now
Old Jul 29, 2008 | 01:31 PM
the LQ9 im looking at is a DBW TB the motor does have the gas pedal and everything would it be hard to convert over being my truck is a cable TB
Old Jul 29, 2008 | 01:41 PM
Cuerva's Avatar
11 Second Truck Club
You'll just have to use your intake.
Old Jul 29, 2008 | 01:50 PM
Tootall's Avatar
all that you're doing is swaping long blocks, nothing else . . . .
Old Jul 29, 2008 | 05:32 PM
So the 4.8s injectors a enough to feed the LQ9 and it will be getting all the mods from my 4.8.
Old Jul 29, 2008 | 05:38 PM
Truckshop's Avatar
your injectors and lq9 injectors are the same.
Old Jul 29, 2008 | 07:36 PM
Mr. Obvious
your truck should be DBW
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
hackrst
Sep 2, 2015 05:27 PM
