What Cam....5.3L
#21
get you something around 220 from comp w/ about a .580 lift on a 112. add a 2600 stall to it and you'll be good to go. should have excellent streetability with that set up. also a good exaust system.
#22
TOTM: June 2007
yah thats the thing...i didnt really want to go with a stall converter really..didnt want to drop the trans out really....but what kind of stall do you recommend...are BM anygood? I gotta get all the shift kit and servo's etc done...so I guess i could drop the trans out
Its got full exhaust..intake, and efans....and gonna tune it on dyno after cam install....
#23
TOTM: June 2007
what do the number mean for cams? 220 etc....? sorry for all the questions guys...jsut wnat to make sure Im well covered...Im thinking I might as well do the stall tho...get a 2800-3000....does TCI make a good unit? Im trying to use my resources of suppliers...might as well buy stuff for cost!
#24
220/220 580/580 112lsa= 220 intake and 220 exhaust ,580 intake lift and 580 exhaust lift, 112 is the lobe seperation angle. As for the tci converter i have seen good and bad with them.
#25
from most of what ive heard the tci lock-up converters are junk and the tci non-lockup converters are pretty good
the first 2 numbers in the cam specs are duartion ( how long the valve stays open)
#28
TOTM: June 2007
K I called Comp...with my mods they recommended a there cam being the specs of a 212 215 522 529 .....how does that sound to you guys....
I told them I want to run a 26-2800 stall...and gave them ym mods...and they gave me that cam...and told me to run a 2400stall....that sounds a bit weak to me tho....I want to run a Yank 2600....sooooo what do you gusy recommend...Im having triuble with this...what they recommended sounds to weak.
#30
Originally Posted by BlackGMC
I have a question, if you got a tr220 with high LSA (114 or 115) wouldn't that have more bottom end than the 112?
