What Cam....5.3L
Originally Posted by nightrunner
its just every time a bigger than stock cam comes up its "you better have a stall or that cam aint worth ****" NO it will just be like a stock cam until it revs up to the power range
JMO no offense to anybody else
Originally Posted by dirt_track_racer_81
ive been in a CC truck with a tr220 and stock converter and was was worse on the take off.. also my buddys 4.8 with a 212 218 cam was worse on the take off..but with that cam in a 5.3 it was better than the stock cam
if you are a comp cam dealer, I would buy it from them... do a custom grind cam... they cost the same.....
if you dont race at the track then you dont need a converter...... but if you do race at the track you will have a very slow take off until the cam's power band kicks in.... need to decide what you want to build... by the way I bought my last custom grind comp cam from speed engineering>>>>>>>>>>>>>>.
TOTM: June 2007
well I dont really want a custom grind..jsut what everyone else is using outta the box. Truck is an occasiaonl driver.and will see the track probably once or twice this summer...Will it be worse outta the hole then it is now? Im not looking for the worlds lumpiest cam..jsut something to give the truck some more kick.....
and for size...what size is everyone else running? what is a streetable size? The numbers given above are those a good cam? Im not gonna lie....Im clueless on teh cma for this truck....
